#54258 02/23/02 12:57 AM
Berbs Offline OP
I don't know how I did it, but I shoucked the "START" out of my '98 Contour.
I know I'm a newbie, here, but can anyone please help?
The chain of events in the matter of a few seconds:
This morning:
  • I got into my contour
  • Had the door still open
  • Began to put the key in.
  • Heard the "DING" from having the door open
  • Door still open.
  • Key going in
  • My index finger came in contact with the metal keyhole.
  • BzZt! SHOCKed!
  • Dinging stops
  • DOOR STILL OPEN.
  • NO MORE DINGING.
Try to turn the key, and although I can twist the key, it's like I never had a key in there in the first place.
Zero.
NADA
No clicking.
NO lights on the display. (ABS, AIRBAG, BATT, SEATBELT, etc... whatever normally comes on when you turn the engine over)
The entire driver side console seems out.
Now,
The interior lights work fine.
I assume the headlights would work but I can't tell since the switch is on this console. Brake lights work. BUT they will not blink when I put on the hazards.
Went to check the fuse-box underneath the steering column, and under the hood, and they all appear to be fine.
So, I can't start my car and I don't have a workaround for this one.
- Berbs
'98 Contour SE
#54259 02/23/02 01:25 AM
Did you check all the fuses?
-Colter
My Car
#54260 02/23/02 01:41 AM
Berbs Offline OP
Twice.
Everything in both rows under the steering column, and whatever fuses we found in the power distribution box. (the ones that looked similar to the fuses in the two rows inside)
I haven't seen a blown fuse since I was a kid, but if memory serves me right, I should see either just a break, or a small "burn" (black spot.
Should I check them again?
I REALLY think it has something to do with the fuses, but so far I'm coming up empty.
- Berbs
#54261 02/23/02 01:46 AM
Yeah they look the same now. :p Do you have a volt meter? If so you can check the voltage on each side of the fuses to see if one of them burned up. Sometimes a flown fuse can be hard to see.
-Colter
My Car
#54262 02/23/02 01:54 AM
Berbs Offline OP
I'll see if my father-in-law has a volt meter (I believe he works at an auto-parts shop)
I guess that way I'll now for sure.
So, you think it is definitely the fuse? Or could it still be something else?
Thanks Again!!
- Berbs
#54263 02/23/02 01:55 AM
I am pretty sure it's a fuse. Try the volt meter first that way you don't have to buy $10 in fuses you don't need like I did.
-Colter
My Car
#54264 02/23/02 01:56 AM
Do you have the V6?
-Colter
My Car
#54265 02/23/02 02:01 AM
Berbs Offline OP
D**N! Sorry, I really don't know much of anything about cars.
I know it's a 4-cyl.
Is a V6 a 6-cyl? If not, how can I find out?
- Berbs
#54266 02/23/02 02:05 AM
Look at your engine. If it says Zetec or VCT or anything like that it is the 4 banger. If it has Duratec on it then it is the V6. The reason I asked is the V6 has a chip in the key for security. The Zetec doesn't.
-Colter
My Car
#54267 02/23/02 02:14 AM
Berbs Offline OP
Zetec.
I'll post whatever I find out tomorrow.
Thank you
- Berbs
