#541993 02/06/03 08:41 PM
I
I
ever since i put the svt duals on my car(96 V6 MTX) it has had this problem...when im stopped somewhere the revs will slightly go up and down between 980 - 1200... and just now it went so low it sounded like it was about to stall out...someone...anyone...help
#541994 02/06/03 08:54 PM
My 96 zetec sport does this too!!! I have no idea wat the hell the deal is?? I would like to know myself. I have a muffler but no dual exhaust on my tour... so i dont think its your exhaust.
#541995 02/06/03 08:58 PM
I
I
but it only started happening when i put it on...then i reset the computer and it went away...alittle bit for a little while now its back....damnit
#541996 02/07/03 12:21 AM
It sounds like you now have a vacuum leak. I would recommend changing the UIM gaskets, they fail easily when they get old. Look for other sources you may have disturbed while doing the work like vacuum lines behind the engine.
If low end power is also affected make sure the IMRC is closing.
#541997 02/07/03 01:32 AM
I
I
Thank you ill look into that tomorrow
