#54041 02/20/02 07:37 PM
My left turn signal started blinking really fast. I assumed that meant I had a burnt out bulb, but I checked both front and rear lights and they're fine, except that the rear one doesn't blink. I'm guessing that I have one of two possible problems:
1. The rear bulb is on its way out and isn't generating enough wattage to operate the flasher.
2. The switch is dirty or defective.
So my question is this: do these seem like reasonable possibilities, and if #2, where exactly is the switch so I can get at it?
#54042 02/20/02 08:18 PM
Light bulb is burned out. Just replace it and you should be fine.
-Colter
My Car
#54043 02/20/02 08:21 PM
When it blinks fast its called the Bulb Out Detector or something like that, just to let you know that one is out.
2000 SVT
K&N Drop-in
Pioneer Face
12" Kicker
1999 se
#54044 02/21/02 05:35 PM
jng Offline
So are you saying that the bulb lights up but doesn't blink? Try swapping the left & right side bulbs and see if the problem stays on the left side or goes to the right side. That should give a better idea of it being the bulb or switch that's bad.
Hopefully it's the bulb, since their only ~$2 for a pair at pepboys.
#54045 02/22/02 03:36 AM
How many CEG'ers does it take to change a light bulb ?
stock 95 LX,6cyl ATX
#54046 02/22/02 02:19 PM
12 eek
One to say change the bulb
One to say check the socket
One to say Sylvania makes a better bulb
one to say Autozone is cheaper than Pep Boys
One to say order it from Bill Jenkins
One to say use LED's
One to say "Use the search function"
One to say he had the same problem and the bulb didn't fix it
One to say you need a HID lights
One to ask where can he get blue bulbs
One to make a smart remark like "How many CEGr's does it take to change a light bulb?"
One to make a smarta$$ answer to the question :rolleyes:
laugh laugh laugh
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#54047 02/22/02 08:50 PM
mc Offline
the same thing is happening to me this week - i thought the rear bulb was burned out but then it would start to work normally
it started to do it again this am so i got out of the car and hit the taillight with the palm of my hand and it started to work properly
my guess is the rear bulb has a bad connection
i bet if you/we clean the rear bulb and check the connection we'll find the problem
mc
#54048 02/22/02 08:55 PM
The taillight bulb is a dual filament bulb right? so maybe just one of them burnt out.
Black '99 Mystique LS Duratec ATX
#54049 02/23/02 10:30 AM
E
E
If the little springs in the bottom of the socket are too flat, it will make the problem happen every now and then.
I want to be the one to reccomend LEDs! laugh
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#54050 02/24/02 07:51 AM
i'm having that problem too..my contacts are coroded though..i have to clean them.
Silver 1998 Mystique LS (v6)...ATX frown
Removed Emblems, limo tint, painted calipers.
Premier P630 HU with 4 Pioneer TS-A6895 Speakers with 10' Sony sub (yeah i know, i'm cheap)
Commando 501-S Alarm
