#53972 02/20/02 12:12 AM
I noticed today when turning the steering wheel hard over to the left, the passenger tire feels lumpy. I can also hear and feel a kind of binding noise in that area. Hope this isn't too vague. Any ideas? Thanks, John
'98 Contour V6 ATX
You know you're in trouble when your Grandma flips you off.
#53973 02/20/02 01:10 AM
ask your wife if she hit a curb eek
#53974 02/20/02 05:37 PM
Air pressure? I'm not sure what a binding noise is but something to check is the sway bar which if it moves back & forth could cause a rub. Check it with the wheels straight to see if it has any left/right play when you pull/push on it.
Scott
#53975 02/20/02 07:19 PM
Bad CV joint. Drive your car in a circle in an empty parking lot. try it left and right. If its really clunking then it could be that.
1998 SVT #95: Toreador Red - SHM headers,K&N Filter, Energy Suspension MM inserts, Cross Drilled Rotors,Redline Tranny Fluid, Custom Billet Aluminum Shift Knob
#53976 02/21/02 12:46 AM
Struts worn out/leaking?
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
