mbb41 Offline OP
So I'm driving along and I notice a lack a H.P.
So I gun it to see if I'm mistaken. 2nd gear takes forever to spool up so I know someting is not right. So I stop the car and pop the hood. Can't find anything. Start driving again give it some gas and notice that the pick-up seems to be restored through first. I put it into 2nd and all the sudden I hear a big gush of air and pressure from the engine. Thinking I've just messed the car up huge I stop again pop the hood play with the throtle and feel exhaust from the rear bank next to the firewall blowing at me. (so its blowing to the drivers side) I manage to get it back to work and set up a time for it to be looked at tommorow @ Ford. Question is what do you guys think this could be. I'm guessing the manifold seal but could it be a cracked manifold. I mean I felt a drop in power just before the nasty happened so could that be a indicator of whats wrong with it???? Any help would be great thanks.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
blockage in cat???
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
mbb41 Offline OP
Recall work was done but if this is the case could it blow a hole up the line?
i am sorry to hear about your car that sucks . maybe an exhaust gasket ?
When in doubt gas it!!
6
6
Not too far out of the realm of possibility, maybe something crawled up in there? I know mice and snake's have been known to do that, trying to stay warm from the heat of the engine. My two cents.
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Plugged/broken cat(s)...The China Syndrome...'core meltdown'!!! eek
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
mbb41 Offline OP
It's being looked at as I type. I'll let you know whom will win the lottery when I find out. I will bet against a snake myself (too cold) but the mouse one sounds interesting wink
mbb41 Offline OP
Yup its the cats sure enough. Can't wait till that gets repaired. Depending on how long they been going bad the car may have more power than I thought.
