Posts: 291 |
the 61,ooo mile atx mystique runs at the high end of the "normal" part of the gauge. after taking an actual gauge reading of 210 degrees, the cooling fans turn on and run until about 200 degrees and then stop and the gauge reads between the "a"and "l" of the gauge. is this a normal reading and if not, what can be done to get a more comfortable reading?
Posts: 546 |
My zetec always run in those temp ranges, when im on the highway moving along it reads in the M area.
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
Posts: 291 |
thanks for the quick answer. some customers want to buy this car tomorrow and now i have to convince them this is ok. your responce helps. thanks again.
tommy daugherty "it is easier to beg forgiveness than ask permission" :p
Posts: 66 |
Originally posted by dealer502: the 61,ooo mile atx mystique runs at the high end of the "normal" part of the gauge. after taking an actual gauge reading of 210 degrees, the cooling fans turn on and run until about 200 degrees and then stop and the gauge reads between the "a"and "l" of the gauge. is this a normal reading and if not, what can be done to get a more comfortable reading? All zetecs run on the hot side of the temp gague. In between A & L is normal. The fan will always kick in when the gague is in the middle of the "L" and turn off at "A" and the temp will go down a little more almost to "M" while at idle . Interesting note - The zetec runs "hotter" in the winter . And it runs cooler in the summer ! Do not know why ? You would think it would be the opposite . And the fan does not run any more in the summer than the winter. Starsky_distributor
Posts: 1,969 |
Originally posted by starsky:
All zetecs run on the hot side of the temp gague. In between A & L is normal. Actually, it seems to be more prevelant in 95-97 contours than 98-00. My 99 barely gets to half way when it is completely warm.
Kharma is very real and she is one mean b!tch.
Posts: 956 |
Originally posted by redhawk:
Actually, it seems to be more prevelant in 95-97 contours than 98-00. My 99 barely gets to half way when it is completely warm. I heard that too !!! It think it's true... The oldies are HOTTER !!!
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 4 |
My 96 'tour with a TON of miles on it just recently went from the M to A and L and sometimes past L. Weather has no effect...coolant has no effect ... oil changes have no effect.
I'm so confused.
02 WRX 96 Contour GL (110k miles and still 33 MPG)
Posts: 122 |
Originally posted by JenisonWRX: My 96 'tour with a TON of miles on it just recently went from the M to A and L and sometimes past L. Weather has no effect...coolant has no effect ... oil changes have no effect.
I'm so confused. Someone made a point in an earlier thread that if Ford were able to manufacture uniform quality temp sensors, you'd see numbers there instead of the N-O-R-M-A-L letters I replaced the temp sensor when it went wrong, and the new one reads always higher than the old one did - and I don't think anyhting else has been changed on the car :p Still in the 'NORMAL' range though. Tivadar
Posts: 401 |
heh, since mine doesnt have anything on it except the temps, mine is always below the middle of the gauge, no matter what...
*fixed* 1998.5 Contour SE Zetec No Cat, SVT Dual Exhaust, 2 N1 Mufflers, IAT , Diablo Chip, Iceman Intake, Polished TB, "new tranny"
Various other crap, no more mods for a while, just moved.
17.391 @ 81.03 mph
1995 Honda Civic CX Hatchback
15.34 @ 91.67mph
stuff.
Posts: 3,165 |
And to throw another twist into the mix, mine used to read at about the M while moving and go up to the A/L when sitting at idle, then go back down once moving again. I replaced the thermostat last summer and before I changed the gauge faces to the BNM ones, it never went any higer than the R at idle and sat at the O most of the time. Of course, sometimes the gauge won't even register or will die and not read at all, so it could be the sending sensor has gone bad causing this to happen...
