Posts: 17 |
Hey Guys,
I'm in the process of installing the s/c and would like to put a larger filter on. Any suggestions.... better yet part #. Thanks Courtney
Back In Black
Back In Black
Posts: 3,119 |
I use a K&N X-Stream filter, but I don't have the part# -Mark
Learned patience the hard way
Posts: 2,454 |
I'm using an S&B powerstack and it clamps right over my 75mm maf.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 1,625 |
Originally posted by Buckshot77: I'm using an S&B powerstack ....... Rick
Me too.
Posts: 294 |
chris is that the same filter the kkm uses?
~nick
2001 Cougar V6 MTX
3L Cougar.
Posts: 431 |
Originally posted by Buckshot77: I'm using an S&B powerstack and it clamps right over my 75mm maf.
Rick
rick,
how can I fit the S&B over a stock MAF? Chris seemed to 'make it fit' with some rework.I'd rather get a larger unit that fits right.
ideas?
d
For Sale: 1998.5 Silver Frost SVT.
Vortech supercharger, ShoShop Y Pipe, Borla catback, DMD, Spec Stage II clutch, Quaife LSD, B+M shifter, Ground control coilovers, Koni struts and much more.
see classifieds....
Posts: 2,454 |
The filter won't fit on the stock MAF without using some type of MAF adapter. On the 75MM pro-m unit you can order it without the flange and the filter slips right on the end of it to be clamped down, but you want to go with the chrome unit because the plastic one will crack with the pressure from the clamp.
Rick
Buckshot77@msn.com
Posts: 431 |
thanks Rick,
do you know which MAF adapter I can use with the stock MAF for the larger S&B filter?
d
see classifieds....
Posts: 976 |
You really can't use the stock MAF, because on the bullet style Pro-M you slide the filter on there are no flanges and bolts its just a tube and because of that you can slide the filter farther up the tube freeing up that extra 1/2-1" you need to fit that large mouth S&B. Check my post "It lives again" there is a link with pictures of my set-up which is the same as Ricks.
Back In Black
Back In Black
Posts: 3,119 |
slightly OT... Kinger, have you dynoed that beast yet? -mark
