Page 3 of 5 1 2 3 4 5
I feel Guilty, Oh so guilty
OK, next question, is there room to put another 11" hole to add another PR. So, you would end up with a 12" sub and two 12" PRs?
"If you are flammable and have legs, you are never blocking a fire exit" -Mitch Hedberg
No
How would I calculate my current F3? I am guessing it is pretty high. I tried playing with WIN ISD,entered the parameters off ID's site, but got nonsense graphs. Clearly, I did something wrong - no subs could sound as bad as the model suggested.
I assume the subs are lined up across the top? or on the 36x13 side, what the orientation may be. in that case, there should be room, or am i missing something?
My mistake, I wasn't thinking. The subs are mounted about 3" in on each side of the box. If I were to use a new front baffle I could use 2 12" PRs.
My only experience with PRs is a old pair of Polk s10 speakers I still use. With a 7" active woofer and a 10" PR they produce impressive deep bass.
Anyway, this idea sounds very interesting so far.
Do you have any problem with possibly using a different amp and subs?
I'm guessing you're using a JBL BP600.1 as a sub amp?
How does a Blueprint BPD 1202 look with a pair of 12" PR's? The sub is 2ohm DVC and can be wired in parallel for a 1ohm mono load to the amp, so it'll get 600w.
BTW, they're $97 from www.audioliquidators.com.
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
F
F
I know it cost plenty of cash
Eclipse SW 9122 DVC Titanium series
JBL 1200.1 amp
http://www.eclipse-web.com/products/speaker/sw9100/sw9122.html
I'm sure the dnewma04 can point out a diffrent sub
2002 Ford ZX2 5spd (2nd baby) Former owner of 1998 Mystique (never filled the shoes on my first love)parents traded for new sable Former owner of 1996 Mystique(My true baby )
The amp I am using is a US Accoustics 800D - 400 watts @ 4ohms - 600 watts @ 2 ohms - smoke and flames @ 1 ohm.
I was hoping to just change the subs.
In a perfect world I would have a Brahma or Stryke with the JBL BP600.
Well, that might rule out the Blueprint line-up. I don't think the BPD1201 doesn't have enough geddy-up for the type of output you're after. The BPD1202 would have to be wired in series for a 4ohm load (only 400w) but could still possibly be enough. The BP1203 appears to deep for a 7" mounting depth you're describing and would only get 400w.
I wonder if a Dayton DSQ might be an option...
The 1203 was what I was looking at, but I think depth would be an issue. So, what we need is a 12 that needs a small ported enclosure with a 2ohm impedance....You aren't making things easy...:)
The 1203 looked so promising otherwise!
Moderated by  dnewma04_dup1
