Page 2 of 5 1 2 3 4 5
#538279 02/03/03 09:47 PM
H
H
i have 19x8's coming in for my mustang.....ill have them on whenever it stops snowing....i know its no contour so its of little help to you, but i hope the rubbing is minimal..ill let u know
#538280 02/03/03 10:19 PM
I
I
Originally posted by reFLex:
How do you know? I think he was looking for opnions from owners of 19x8 wheels on a Contour...
because I read responses from owners with 19x8 wheels on a Contour
#538281 02/03/03 10:47 PM
Q
Q
Originally posted by Antonio Wright:
Originally posted by unknown:
Originally posted by JiggaJerry:
19x8 will rub
Not to say otherwise but I know of at least 1 CEGer who claims he ran 19x8 axis 7s w/a 45mm offset and had little rub. I believe it was lilbern who had that setup. I just dont understand.
IIRC his car was not low enough. My car is slammed to the ground and I rub like hell. At first it was the lip, but now it is the actual wheel liner in the front and rear.
-Antonio
Yes, lilbern said he ran 19x8's, 45mm offset, with 215's without any rubbing issues. He also stated he had a 3" drop on the car at the time. I posted my opinion on this subject many times. It seems like the tire size is more of an issue on the rubbing. Lilbern also stated he had some 18x8's with a 42mm offset. He said with 225's they rubbed.
Until I get under a car and actually see the clearance, I'm going to assume they will rub no matter what.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
#538282 02/03/03 10:53 PM
Yup. In the end, the size of your tires determines the overall width and diameter, not the wheels.
-Giovanni One turbocharger. Two intercoolers. All love.
#538283 02/04/03 12:21 AM
I didn't rub at all with 19x8 45mm offset and 215/35 tires.
I rub like a biatch with 19x7.5 42mm offset and 225/35 tires.
Bernie
#538284 02/04/03 12:51 AM
Q
Q
Bernie
Ooops...off on my quote of 18x8...don't know where I pulled that out of. Sorry about that.
#538285 02/04/03 04:41 AM
BDR Offline
get em!
i wanna see an SVT with 19"s rollin around town!!
2000 CSVT (SOLD) #531/2150 now 2003 WRX !FINALLY SPONSORED! "Big Pimpin, Never Slippin"
#538286 02/04/03 04:42 AM
U
U
So if I went w/a 19x8 rim, a 215/35 tire and around a 45mm offset I should have little rub? BTW, I have the eibach spring set which claims a drop of 1.25" or there abouts..
2k silver svt #1721 Ignorance breeds stupidity..
#538287 02/05/03 12:20 AM
You will be just fine.
#538288 02/05/03 06:09 AM
Like Antonio said, if you have your car hammered, the wheels will rub, but all it takes is trimming some of the fender liner in certain places. I've ran 18x8 with rubbing issues, but the trimming took care of all that. The 19x8 I have sittin gin my garage have about the same overall diameter with tire as the 18x8. (225/40/18 on the 18 and 225/35/19 on the 19)
If you're gonna do it, step up to the plate and do it right!
Chicken Shift
Moderated by  1314_dup1
