#537994 02/02/03 11:59 PM
I was looking on ebay motors and found this chip. I don't know if it has been posted before or not, so I'm attaching the link. The part comes from Ca. I've got mine ordered just out of curiosity.
Here's the linkhttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2401482954&category=6776
Bizkit
'97 GL '95 Escort lx
#537995 02/03/03 01:02 AM
"invalid syntax error" how do i get one for my car?
-//Stefan//- Aim: TearGasParade
#537996 02/03/03 01:45 AM
2
will you feel it, maybe, increase hp ehh slighlty, 20 hp nope never not on a turbo'd tweaked out zetec.
my 2 pennies
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
#537997 02/03/03 02:17 AM
W
W
biz... u should of asked me, i'd of made u it for 10 cents.
#537998 02/03/03 06:52 PM
CEG road warrior
CEG road warrior
Can you say rip off?
#537999 02/03/03 09:59 PM
what is it? I CANT SEE!!
NEED AN SVT REAR BUMPER!!! pm me
#538000 02/04/03 01:02 AM
is this a knock off af a diablo chip?
#538001 02/04/03 01:27 AM
N
N
It's BS, it just includes some stuff that you can modify your car with that you just can buy at a store. Except they charge you 5 bucks, and 10 dollars for shipping
1998 T-Red CSVT 3.0L
#538002 02/04/03 01:37 AM
what it is is a resister that you put into the wiring harness that hooks into your MAF I beleive. It just fools the computer into thinking that the air coming in is 32 degrees. i'm one of the jacka$$es that bought one and LMAO when i got it in the mail. we all make mistakes
PRIME-TOUR You're fired! I write the books here! ~Tom~
#538003 02/04/03 01:56 AM
It is a 22K Ohm resistor that fools the PCM into thinking that the intake charge is around 65 deg. You may not even feel a gain with this low a resistor rating. Go to Radio Shack or any electronics store. You need to get a resistor with more resistance. Look into a Haynes manual and you will see that about a 40K ohm resistor will give you some gains, but not 20HP or even 5HP... more like 2 or 3HP with the possibility of frying your O2 sensors and your cat!! Don't do it unless you are trying to make up for a mod that has made your A/F ratio too lean (I.E. MAF mod)... In that case, go for it!!
This way you will stay away from detonation, but still get advanced timing and less intake restriction. Maybe 10HP this way. Give or take. If you do this mod anyways be sure to only solder the resistor into the "return to PCM" wire.... ! not both wires! If you follow the idiot that sold you that $.10 resistor by his instructions, then you will get a C.E.L. THE AIT SENSOR HAS TO REMAIN FUNCTIONAL. ALL YOU WILL BE DOING IS GIVING IT A "BOOST" per say!
Without a pre-existing leaning mod, you won't see very much gain if any!
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
Moderated by  Loco4G63
