Well, there are a couple of ways...
Post documentation
Provide reference documents
Pictures
The simple fact is, you have posted something that is somewhat confusing for a person who just replaced and engine with a rebuit unit. I think it is only fair to explain where your information comes from so that they can see the difference between a re-built unit and a new one.
Even if every new engine is tested before, here are couple of issues that I would like to know. And if you are familiar with the procedure, you may be able to answer some of these:
Are the engines tested on engine stands, mounts, etc or when they are in the car?
How long are they tested?
Is the engine pre-oiled, tested, drained and refilled? Or just run and stopped after pre-oiling?
Is there a seperate line that only tests engines?
How many engines are tested per day?
It seems to me these are all variable to consider when evaluating the depth and scope of the pre-testing.
I understand you may not know all these questions and I don't want to seem combative but I do think it is necessary for the original poster to understand the difference from a new engine and a remanufactured one. Since you are in the know, you can help them out.
Plus I would like to know because I'm a geek!
