Page 2 of 4 1 2 3 4
#53701 02/19/02 04:22 AM
I don't know the specifics of the changes but I believe they relate to the pressure relief valve. Anyway, the current pump works all the way back to the first Duratechs.
#53702 02/19/02 04:47 PM
Time to look into extending your warranty. Considering you'll have a renewed engine there should be no reason to ditch the car yet. However when I had my ztec replaced by an inferior dealership (18 day replacement on a 8 hour job) multipul things went wrong shortly after. Replaced 3 cv joints within 1000km's and had to have the sway bar adjusted. I think these were related somehow since they put the engine in from underneath the car. When I challenged them on why I was charged for the sway bar problem they told me the engine was put in through the top of the car. (something the mechanic said was not true) Anyways I paid for the sway bar repair $75 and the warranty paid for the rest. Point to the story is if it ain't put back together right in the first place it may need some tweeking afterwards. An extended warranty is good piece of mind any way you cut it.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
#53703 02/19/02 04:48 PM
If you really like the car...ask your dealer about buying an extended warranty before your basic one expires.
99 SE Sport..ATX
SVT exhaust
SVT zip tube and air cleaner assembly
Tinted windows
17" Cougar Zn Wheels
#53704 02/28/02 02:06 AM
Just an update.... Ford replaced my blown engine with a rebuilt one and provided a 24 month/24000 mile warranty. I was disappointed that it wasn't a brand new engine but the dealership claims that Ford will supply a new engine only within the first 12 months. After that, they will use a rebuilt engine. Interestingly, they will provide only a 12 month/12000 mile warranty on a brand new engine.
Anyway, the 'tour is back on the road and it runs fine with the new engine. Think it's time to look into that extended warranty program....
Thanks to all who posted.
Driver3000
Green '99 SE Sport V6/MTX
#53705 02/28/02 03:42 PM
Somebody posted it here a while ago that a rebuilt engine is better than a new one in that a rebuilt engine will be tested before shipping whereas a new engine may never be tested unless it is picked off the assemblt line.
Makes sense...good luck anyway.
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
#53706 03/01/02 02:48 AM
Marko, whoever posted that doesn't know much about what goes on in Ford engine assembly plants. Every plant that I know of runs every engine through a short test cycle. Sampling of production engines is also done where they are put through much more extensive testing.
#53707 03/01/02 06:29 AM
most motorcraft filters are made by purolator.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
#53708 03/01/02 06:36 AM
9
9
I'm glad my engine is doing fine so far...although, I always have my basic maintenance done at my dealership so that when something does go wrong, I can blame them...
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
#53709 03/01/02 05:34 PM
driver where in wisconsin are you? i started my car the other day and it the engine just bucked and running rough, after i hit gas lightly it went away, my oil is val durablend... almost time to change, i think i will now...
1999 T-Red Contour SE Sport
#53710 03/01/02 08:06 PM
You certainly seem to like to post on things like assembly line processes and oil pump re-designs. Do you work for Ford? Because, so far I haven't seen you back any of these statements up.
BTW- its spelled Duratec, not Duratech :rolleyes:
Kharma is very real and she is one mean b!tch.
Page 2 of 4 1 2 3 4
