Posts: 477 |
Anyone try Bosche's O2 sensors? Supposedly they've got something specail that makes them 15% better than others (according to their marketing).
1996 Contour SE Red V6 MTX 1995 Contour LX Champaign V6 ATX (my wife's beater) SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Posts: 1,969 |
Aren't the stock ones already made by Bosch?
Kharma is very real and she is one mean b!tch.
Posts: 3,419 |
When I got one through Bill Jenkins, the Motorcraft box had "Made in Japan" label on it. Leads me to believe that OEM is NGK.
Posts: 477 |
Autozone.com only lists one kind of O2 sensor for the 95's. Are the two O2 sensors in the 95's the same part?
Posts: 765 |
IIRC, the 95s don't have the downstream O2 sensors, just 1 (4-banger) or 2 (V6) upstream sensors. I can't think of any reason, other than wire insulation color, why the two would be different.
1999 Contour SE Sport MTX75 T-Red/Grey Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1 Other: cup holders, cargo net, Blizzaks, Potenza RE950s
Posts: 1,701 |
Yup, 95 O2 sensors (V6) are both the same and are located before the pre-cats. IIRC when I replaced them, the wire insulation colors were the same. (white, white, gray, black) The aftermarket replacements were the same part # and exactly the same. Originally posted by DiodeBoy: IIRC, the 95s don't have the downstream O2 sensors, just 1 (4-banger) or 2 (V6) upstream sensors. I can't think of any reason, other than wire insulation color, why the two would be different.
Posts: 5 |
Thanks to all the posts & advice from all CEG'rs,I just purchased & installed both upper & lower Bosch sensors on my 96 zetec(140,000mi) Ford wanted around $120.00 per sensor.....since the Bosch's were about half the price at my local Advance Auto store, I asked the dealership if they would install them too at 120 bucks each...He laughed and said I should use the Motorcraft sensors and then I laughed. The car is running as smooth as when I bought it & I am getting around 32 miles per gallon.That top sensor was a real ***** to get out. Be careful.Buy the Bosch's!
2 Contours '95 & '96 mtx zetecs & '99 hugger orange Camaro SS vert just for fun
Posts: 5 |
Posts: 477 |
sweet! I'm going to have to get those then. the LX is getting only 240 Miles to a tank of gas at 93k miles! AND I just cleaned the whole upper intake manifold and throttle body on it too! Can't wait to fix that sucker!! Thanks for all the input guys
Posts: 219 |
Does anyone have a "How To" on this? It would be a great add-on to this site since some of you guys seem to be doing this anyways. With nearly 140k on my 95 V6, I'm sure I'll need to do it soon as well. Just noticed a new CEL, and wouldn't be surprised if that was the culprit.
Thanks, Zack
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
