Posts: 30 |
You dont need to use the dremal tool .
Posts: 2,061 |
wow all this uproar....i put my ford racing wires on during the summer and had no problem with length...over the yrs with different cars i've never seen replacement wires that were exact same length and the originals i replaced...big deal...as for the looms or whatever they're called i put the wires in teh bottom parts and left off the covers...they stay in place just fine...dremEl if u want or dont...just stop the madness
99 expedition eddie bauer, 5.4 v8, k&n drop-in, 3" magnaflow catback and gas mileage that makes the contour look like a hybrid
Posts: 1,420 |
I will have to post a pic , ALTHOUGH i must admin , i have seen a BIG power increase and i think gas milage,I swear i have a new engine in my car . im happy with them.
Posts: 26 |
I called Bill. The only 4 cylinder wires he has are for the Escort and Focus 2.0l Zetec. Does anyone if it'll fit? I'm guessing no...
Posts: 6,760 |
how much 10-20hp? I'm curious as I've been looking at these too. Originally posted by CitatioN10: I will have to post a pic , ALTHOUGH i must admin , i have seen a BIG power increase and i think gas milage,I swear i have a new engine in my car . im happy with them.
Ryan
Trollin!
Posts: 3,867 |
Originally posted by RTStabler51: how much 10-20hp?
Dream on.
From what I've read, you may get a couple hp over OEM, but the biggest improvement will be the fact that you have new wires vs old, so better ignition, fewer misfires, etc.
Function before fashion.
'96 Contour SE
Posts: 1,420 |
I really cant say 10-20 HP, but for sure more HP. 5-10 maybe ? I cant notice a hell of a diffrence , like i said it feels like i got a new engine
Posts: 1,603 |
Okay guys, settle down here...
First, the 9mm wires are better performing than Stock only because
they can deliver a hotter spark than the OEM wires.
Second, the 9mm FORD MotorSport wires are slightly longer than the original wires.
I'm only talking a few inches longer, not a foot or more...
Third, you WILL need to Dremel out our stock wire retainers (Looms)
because they were made to fit the 8MM OEM wires exactly.
You don't need to remove much material.
I did my retainers with a stone that was exactly 9mm in
diameter that came with my Craftsman Dremel kit.
They wires fit perfectly with just a little slack on both the Coil and Spark plug ends.
After the installation of these wires, your engine may idle a little more smoothly
and you will feel a sense of more pickup since the plugs are firing a little hotter.
I doubt you are getting more Horsepower.
I installed my wires with a set of Bosch Platinum +4s,
and they have been running great for over 30,000 miles now...
Not everyone gets the same results as I do with these plugs, but I wish that they did.
They work great for me.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 4,713 |
Just ordered a set. I just couldn't justify buying another set of Magnecores. (I jacked a wire the other weekend...) Thanks for the info, ibub!
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 3,867 |
Originally posted by RoadRunner: Okay guys, settle down here...
First, the 9mm wires are better performing than Stock only because they can deliver a hotter spark than the OEM wires.
Second, the 9mm FORD MotorSport wires are slightly longer than the original wires. I'm only talking a few inches longer, not a foot or more...
Third, you WILL need to Dremel out our stock wire retainers (Looms) because they were made to fit the 8MM OEM wires exactly. You don't need to remove much material. I did my retainers with a stone that was exactly 9mm in diameter that came with my Craftsman Dremel kit. They wires fit perfectly with just a little slack on both the Coil and Spark plug ends.
After the installation of these wires, your engine may idle a little more smoothly and you will feel a sense of more pickup since the plugs are firing a little hotter. I doubt you are getting more Horsepower.
I installed my wires with a set of Bosch Platinum +4s, and they have been running great for over 30,000 miles now... Not everyone gets the same results as I do with these plugs, but I wish that they did. They work great for me.
Not our cars, I know, but GRM did test several "stock legal mods" (Solo II) a while back, but I think it was on a Saturn. Anyway, stock plugs beat all others, and wires made a difference of about 1-2 hp with the magnecores.
Our cars could be different, and the FR wires aren't the same as magnecore, so could be a bit more or a bit less. My point is, some gain is possible, but probably not measurable except on the dyno or on the track.
'96 Contour SE
