Page 2 of 2 1 2
#5357 03/17/02 10:12 PM
E
Evil1 Offline OP
E
I went to napa a bought 6 quart of synthetic almost $5 a quart and I bought a napa oil filter and some brake quiet and that came to $36.04. The branke quiet was $1.50.
'98 Contour se V6 auto
Blue headlight,foglights, and green backup light and green underbody neon
Clarion Pro Audio headunit
6x8 Audiobahn up front
6x8 Infinity Kappa in rear
all new system coming soon
slimshorty42@hotmail.com
#5358 03/17/02 10:30 PM
1 problem with over filling your oil, is that there is the chance of blowing out your seals. But if you only use 1/2 qt more it wouldn't be that big of a problem. but if you run 1 qt over like some there is a high risk of blowing out your seals.
On another note I just changed my oil and went with 5w30 Mobil 1 Syn, I put 5 qts in, 1/2 qt over recomendation (sp?) but after the pressure check it was only 1/8 qt over full? I guess the Purolator oil filter is a little bigger than the Fram I had last time.
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
#5359 03/18/02 04:22 AM
Q
qaz Offline
Q
Originally posted by Roger R:
There was a post in here a couple weeks ago stating that someone at Roush did a test on the 2.5 Duratec and at 5000 rpm there was less than one pint of oil in the pan
I have my doubts that there is enough room in the upper part of the engine to hold 5.8 quarts of oil. Think about how much volume that is (roughly 1.5 milk jugs worth), and how much space there is in the engine for oil to collect.
Brian
#5360 03/18/02 05:20 AM
6 quarts of MOBIL 5w30 = 24 dollars
1 purolator pure one oil filter= 5.99
the feeling you get when you do your own oil changes + agony that engulfs you when all of the oil comes out fo the filter and splashes on the exhauist manifold and gets everything all messy = priceless
99 T-RED SVT
50,555 Miles and counting as off 7/12/2002
born jan 99
UR underdrive pulley
A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg
B&M short throw shifter
Eibach Springs
BAT Sturts
White Faced HVAC
2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP
Cup Holder Upgrade
PIAA super white Lows
Whelen 90watt 6 bulb strobe kit
Front end motor mounts
Mods waiting for install
3L(job has alrady begun, 3L totaly stripped.)
Quaife LSD
Apexi s-afc
Mirko splitter
Page 2 of 2 1 2
