#53515 02/13/02 04:36 PM
N
N
I just came back from the second of two trips to Chicago. I checked the fuel economy and I was running close to 23 mpg. The changes to my exhaust between the two trips are as follows.
I added 2 x 2.25" 12" long CATCO cats, MSDS headers, and different style mufflers. The HP definately felt lower when I changed the exhaust, but the new mufflers should have flowed better. I had something close to 165 on the dyno with true duals, MAFS, headers, & KKM. I got it optimized to 177 with a few more tweaks.
Before the change, I dynoed at about 170 with only the catless SHOShop y-pipe (no true duals), MAFS, & KKM. I also got 30 mpg to Chicago...easily.
I am not sure if there is a correlation here, but if I lose 7 mpg, can that all be attributed to the cats or am just more inefficient now somehow? Also, is there any correlation between lower fuel econ and hp?
Thanks! confused
98 Black E0 #946 of 6535
Koni struts & Eibach springs
24mm Aussiebar
Pro Flow 75mm MAFS calibrated to KKM filter
Wilwood Brake Kit with cross-drilled rotors
Clutchmaster's Stage 1 Clutch & Fidanza Flywheel
Custom Dual Exhaust with an Xpipe
MSDS Headers
Custom Cold Air Intake with KKM filter
Dyno'd at 177 hp and 156 ft-lbs
#53516 02/14/02 01:44 AM
Assuming no technology changes (bad assumption), engine calibration is largely an exercise in balancing performance, fuel economy, and emissions. The rule of thumb is that in order to improve one of these characteristics, you will take a hit on at least one of the others. There are many exceptions to this rule, but for the casual tweaker, it is probably true more often than not.
1999 Contour SE Sport MTX75 T-Red/Grey
Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1
Other: cup holders, cargo net, Blizzaks, Potenza RE950s
