Page 2 of 3 1 2 3
im glad i wont have to do that...first thing im gonna do when i get my 3.0L is put on those turbo manifolds so i dont have to deal with it once its already in the car.
the V8 SHO motor is a combination Ford/Yamaha. Yamaha worked on the topend.
Originally posted by Stazi the Aussie:
I know what you're saying, but I think you are a little confused. The V8 isn't a Yamaha, the old V6 in the older generation SHO's was the Yamaha. The last SHO's had a V8 derivative of our Duratec. But those things have their problems too, including catastrophic failure of the valvetrain...
Ryan Trollin!
It's on a hoist!
The plain truth of the matter is that it''s just too cramped!
Terry knows what he's saying when he says to drop the whole engine and subframe out to do this kind of work!
My engine was sitting on a jack close to the floor but still in the bay. Give you an idea the top of the bell housing was even with the top of the inner fender/ apron. Yeah my hands are not small either maybe you should try to find some dwarfs to work on your car. I shall call him turbo dwarf. muhaaaaa hahaa
98CSVT specII yada yada yada 95 Mustang GT M&M road&track box HP stage one 60-mm
W
W
Don't worry about it, it isn't the turbo manifolds that are so hard to install, it is the factory manifolds that are so hard to pull off. The msds headers are a little easier to pull off than the factory manifolds, but still a PITA. At least the alternator doesn't have to come off again.
warmonger
#535044 01/31/03 02:46 AM
Originally posted by DemonSVT:
I did my header R&R in around 3 hours total. (2hrs rear, 30 front (maybe), 30 everything else)
Would have been quicker if the upper alternator bolt wasn't put on by some Ford moron using an impact wrench (I broke a ratchet and a socket getting it off ) That took a good 30 minutes alone. I was so pissed!
Mine has the large rear bracket so it had to be moved to get the manifold off.
All I can say is; "I swear by gearwrenches!" ...and I mean REAL ones... Not crappy imitations like the POS fat ones that Craftsman and others make.
what is a gearwrench? and what company makes good ones?
#535045 01/31/03 03:52 AM
It is a combonation wrench that the boxed end works like a ratchet.
"GearWrench" is made by KD Tools
Stazi Offline OP
Actually the stock manifolds came off easy.
I had the motor hanging so low, so that you could see the starter motor through the wheel well! Like an angle of about 20°!
The problem is that the turbo manifols with 1 7/8" primaries are HUGE and so a couple of bolts allowed just and allen wrench to install them which takes a long time when you can only turn the bolt 1/8th of a turn at a time That's the price for power I guess...
Also I had to "massage" the primary tube adjacent to the alternator as both of them wanted to occupy the same place. An oxy-acetylene torch and a hammer and all is good now.
(I also wrapped that primary with insulation to protect the alternator)
I told StreetFlight about the inteference and they will remedy that in all their kits.
We have pics so I will try and get canamSVT (thanks Ed, for you help) to post them soon.
#535047 01/31/03 01:15 PM
Learned patience the hard way
Stazi do your hands look something like this? Hehe, I feel your pain man!
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
#535048 01/31/03 01:18 PM
Stazi Offline OP
Worse, I have chunks missing out of knuckles. OW!
#535049 01/31/03 02:08 PM
Wow Rick, You have some manly hands there...
2003 Sonic Blue SVT Cobra Coupe 2003 RedFire SVT Cobra Convertable 2005 Dark Toreador Red F150 XLT 4x4 2000 Black SVT Contour - Beater
Page 2 of 3 1 2 3
