Posts: 9,602 |
Originally posted by 96zetec: Umm what if the precats are already gutted... what do you mean problems??CEL's?? If its just a light I can live as long as my car is faster, I make sacrifices
This sacrifice causes the car to run in limp mode. (I.E. very rich! drops power!)
Build some MIL Eliminators. Easy, cheap and very effective.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,055 |
and the best place for those are.....Airknight did you have to use them with the obd1 setup??
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 1,977 |
Absolutely no need for MIL eliminator, there is no pre-cat efficiency monitors on the 95's.
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by DemonSVT:
Don't forgot about making/welding in all the hanging points (minimum: 5)
Yes it is "technically" possible to build your own downpipes from mandrel bends but it would take several bends (figure around $50 in bends) and would be very messy and easy to screw up (uneven inside!)
Also you would need to weld on spherical flanges to be able to mount them to the manifolds/headers.
Actually the manifold pipes are quite, quite easy to build. I had a local shop stub out two pipes for me with 45 degree flanges pressed into them. Cost all of two bucks. Then, I used a 90 and two 45's to make the front one. The rear one, I used a 90 cut off just a touch early... I could have used a custom bend from West Coast bending in retrospect... about a 75 degree bend or so is needed. Welded an O2 bung (another buck) to the rear pipe after I was done tacking it in place. Took an entire afternoon to finish the rest of the system. Total cost was under $300 for the entire system in 2" piping, including cheap mufflers.
The hangers are easy as pie. Get a cold rolled 3/8" steel rod from Home Depot or the like and bend your own hangers after tacking the pipes in place.
http://www.bnmotorsports.com
Posts: 1,055 |
what about going stright under the gas tank brad?? Espically if I made a heatshield and used exhust wrap?? thanks
Derek Johnson
95SE 3L gone
Redneck Troll
Redneck Troll
Posts: 2,621 |
I didn't like the idea of the exhaust being the lowest thing under the car. Straddle one high center point and put a hot exhaust through a plastic gas tank??? I don't think so...
Posts: 1,055 |
do you know of any underbody pics of cars with true duals?? I've searched and searched to no avail. thanks
Derek Johnson
95SE 3L gone
Posts: 1,977 |
Micah tried running it straight and under the gas tank. Ask him how he liked it. I personally don't like the pipes hanging so low.
Posts: 217 |
96zetec,
You should check out the Tuffy that just opened Monday on Broad and Waggoner. They have a mandrel bending machine and a variety of pieces over there to put together an exhaust.
I'm taking my Mustang over there for exhaust work and am considering having them do a y-pipe optimization for the 'Tour.
George Hodge
New: Volvo S60R
Old:2000 SVT Silver Frost 1188/2150
DMD, 75mm Pro-M, HPP rear strut tower bar
Aussie 24mm sway bar (with boxed in subframe)
BAT European Handling Kit, Brullen Y-pipe
Performance Ford spherical bearing end links
Posts: 2,469 |
Originally posted by bnoon: I didn't like the idea of the exhaust being the lowest thing under the car. Straddle one high center point and put a hot exhaust through a plastic gas tank??? I don't think so...
thats a very good point.
