Posts: 9,602 |
Originally posted by bnoon: I didn't like the idea of the exhaust being the lowest thing under the car. Straddle one high center point and put a hot exhaust through a plastic gas tank??? I don't think so...
The exhaust would not even hang as low as the sideskirts or front bumper. If the pipe were even touched either the front bumper, sideskirts or both would already be gone.
Also there are 3 layers between the fuel cell and the piping with the outter one being re-enforced ABS shielding. (to protect from crashes!)
Also I ran the F-body setup for over a year and it hung about 2" lower than his setup will and I never bottomed it out once.
I'm not worried. Saving those 4 90 degree bends and 60+ inches (each pipe) is well worth it performance wise!
Besides at least 2 people have been running that setup for quite some time with no problems.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,055 |
well I'll be a third then  and it'll be cheap as hell
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 2,469 |
wouldnt you have to have some slight bends in the pipe for it to come back up past the gas tank so that the tips would hang right and not 6' below the cutouts if that makes sense
Posts: 9,602 |
Originally posted by dubkatz: wouldnt you have to have some slight bends in the pipe for it to come back up past the gas tank so that the tips would hang right and not 6' below the cutouts if that makes sense
That's the beauty of piecing together 90 degree mandrels. You can just rotate the angles to change the positioning.
That's how I did my F-body setup with only 2 total 90 bends after the muffler. With 4 bends in this setup getting the proper angle will be cake.
2000 SVT #674
Posts: 661 |
Originally posted by DemonSVT: Originally posted by dubkatz: wouldnt you have to have some slight bends in the pipe for it to come back up past the gas tank so that the tips would hang right and not 6' below the cutouts if that makes sense
Greg you stole my idea, no wait, I stole yours yours. Will have all my exhaust stuff at my door within the next week
Fast Cheap reliable
Pick two
Posts: 9,602 |
At the rate I am going you may have yours on before I do mine though...
2000 SVT #674
Posts: 661 |
Originally posted by DemonSVT: At the rate I am going you may have yours on before I do mine though...
Hmm sced delivery is tomorrow, might be a nice weekend project ahead of me.
Fast Cheap reliable
Pick two
Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by DemonSVT: Originally posted by bnoon: I didn't like the idea of the exhaust being the lowest thing under the car. Straddle one high center point and put a hot exhaust through a plastic gas tank??? I don't think so...
How many people high center the side skirts? Straddle one piece of road debris and the pipe would be toast. As many times as I killed the 3" SMA exhaust just running it under the rear suspension subframe assembly, I'd never intensionally do anything like that again, especialloy with a gas tank involved.
On my SE, the exhaust would be the lowest thing around going under the tank. Bad joo joo to mess with...
Is your car lowered at all???
http://www.bnmotorsports.com
Posts: 9,602 |
My car is stock ride height. Well actually probably a bit above stock height. (weight loss raised it)
Anything that would hit the pipes would take out the front bumper either way. I don't go off roading so that's not a worry.
If I hit any animal my car is screwed already so I don't see the problem. Don't run into things - That's simple
Also like I said; I ran the F-body setup for over a year. It hung at least as low as the lowest ground effect's point and I never bottomed it out once. This setup will be 2" higher than the ground effects. That's a mile compared to the ground clearance on the ground effects.
I suppose we could ask Micah to chime in. His car is like 2" off the ground. Wonder if he has bottomed the pipes out...
2000 SVT #674
Posts: 1,055 |
well i bought micah's sides and rear off his champaign lx, and thye'll be going on a 95 se which will most liekely have the roush/st200 setup off my other car on it. That seemed to lower about 1.25 in the front and about 1.6 in the back.. now am I reaching a danger zone??
Derek Johnson
95SE 3L gone
