Page 2 of 6 1 2 3 4 5 6
#534872 02/01/03 03:43 AM
go buy some wrinkle bends from pepboys !! thats the way to go !
jk man, i dunno about exhaut
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#534873 02/01/03 06:09 AM
Originally posted by BANDIT:
Better scavenging? What size pipe are you thinking of using? There is a saying to much of a big pipe does not equate to improved HP or torque. Just my .02
Well you seem to not understand the concept & design here.
Dual exhaust pipes would be smaller in diameter than a single pipe exhaust setup or subsequent "quasi-dual"
For instance 2" duals versus 2.5" single piping...
In this comparison the duals have ~28% more flow volume, but being smaller piping they would achieve higher exhaust velocity versus single piping because the exhaust is expulsed in pulses. Not total volume.
There has been a couple great threads about this in the last month or so. You should search them out.
#534874 02/01/03 09:03 AM
Hear, hear.. I read through all of them, even though I know nothing about exhaust setups..
Ray
#534875 02/01/03 12:31 PM
You need to talk to Stazi in the SE MI forum to see if he can still get the X-pipe and flex pipes. I got them from him along with the Magnaflow resonaters (which you'll need, trust me!) and Magnaflow race mufflers. Also don't gut the pre-cats, its not worth the headaches that you WILL get
#534876 02/01/03 02:15 PM
Just remember NO balance/X-pipe is better than a misplaced balance/X-pipe.
#534877 02/01/03 03:42 PM
2
Umm what if the precats are already gutted... what do you mean problems??CEL's?? If its just a light I can live as long as my car is faster, I make sacrifices
thanks,
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
#534878 02/02/03 12:06 AM
thanks,
yeah, i think roger has replaced the O2 sensor at least once in his car and i believe hes had quite a few cel's.
#534879 02/02/03 12:26 AM
CEL is not going to be a concern for him, just like it's not a concern for me. OBDI ownz!
#534880 02/02/03 03:53 AM
Actually I've replaced (3) different O2 sensors in the past year, code #0144, #0136 and #0156. If you have a great flowing exhaust I can't see gutting the pre-cats making that much of a gain to justify it. I mean REALLY, how much are you going to gain in hp compared to the gain in CEL's your going to get? One thing you'll need and it may save you money in the long run, is some type of scan tool that not only tells you what code your getting but one that tells the millivolts your O2 is putting out. I say this because that CEL could be your MILS (homemade or store bought) going bad and yes I have experience here too In closing think about this, is the extra 3-5hp worth the headaches of CELs, CELs because of defective "homemade" MILS, defective store bought MILS which cost about $70.00 by the way (that could be money spent towards another mod i.e. bigger used TB), see what I mean
#534881 02/02/03 05:21 AM
Every bit of HP costs money. Every bit counts when you add them all up.
