#53377 02/11/02 11:20 PM
PhatSVT Offline OP
Well I bought the 75mm ProM from wavrdvr and installed it this weekend and started the car up. The car started fine but when came to idle it was very rough and eventualy died. I have the optimizer but its broke in areas. The MAF was for a 2000 Contour SVT so do I need to send my chip to Superchips for reburn or will the optimizer take care of this idle problem?
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
The Mass Air meters are calibrated to a specific code that is on your original mass air meter. Unless your meter and wavrdvr had the same code it isnt going to work very well. If you get in touch with Pro-M they will be happy to recalibrate it for $100, the optimizer is supposed to be used for making changes in A/F by changing the voltage that is sent to the PCM from the mass air.
99 T-Red SVT #1634/2760
K&N filter
Aussie Intake Pipe
Pro-M 75mm & Optimizer
B&M Edge Shifter
Quaife LSD
Borla Cat back
MSDS Headers/sho-shop Y-Pipe
Dynoed at 184.2 HP & 157.2 TQ
14.53@94.15
PhatSVT Offline OP
Well that sucks since i payed $145 for this used. now pay another $100. So i just got raped. cool.
Sam
AOL users = PhatSVT
1986 Mustang GT
12 second club
Buy a SAFC!
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
Hey PhatSVT,
Did you RESET your PCM before you restarted the engine??
This allows the PCM to relearn to idle.
While the PCM may not be able to fully compensate for the new Mass Air Flow, what ever it lacks, you could have reburned into your SuperChip.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Originally posted by PhatSVT:
Well that sucks since I payed $145 for this used. now pay another $100. So I just got raped.
Unfortunately... frown
MAF's are calibrated by 4 things:
Filter type (conical or panel), injector size, Model Year & Original MAF Number
2000 SVT's had a completely different MAF, electronics, and casing compared to any other Contour year.
Like Buckshot said you could probably tune it correctly with an S-AFC... Though that adds $300 and $100 dyno time at least...
2000 SVT #674 - Check it out!
4
4
The TPS Throttle Position Sensor might have gone out of range when you reinstalled it.
98.5 SVT
93RX7
86GT 377ci
haha poor sam wink smile
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
???When installing a MAF???
Also that would throw a code too.
4
4
my bad. I re-read the post. I was thinking that he replaced the throttle body and the MAF with a 75mm. at same time.
98.5 SVT
93RX7
86GT 377ci
