Posts: 57 |
I would like to buy one from Aussie. Can some one post pics on how to install?
Posts: 624 |
Stolen pic.
Sold 1998 Contour LX 13.868 sec 1/4 mile time.
Two years of rental cars, seriously.
Holding out for 07 Cobra Mustang.
Posts: 1,469 |
Few Qs..
I have one that I have not installed because I was unable to open the little stopcock valve at the bottom....I broke it with vicegrips tryig.. It IS supposed to open & close to drain the oil right??
Also, I noticed I checked it for airtightness by blowing into the thing. Seems to leak at one of the brass fitings. It is supposed to be airtight, right?? I could probably fix it with epoxy.
Thanks
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 9,602 |
I seem to recall seeing that picture somewhere before...  Dan - Yes the bottom piece is a drain. No part of this should leak. That would be letting in unmetered air & also taking away from the venting of the crankcase (as it would be pulling in outside air instead of vented crankcase vapor)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 736 |
Ok I see a nice purty engine compartment and I see the separator, first off it's not a Zetec, second how do you install it on a zetec, third...nah never mind the third.
99 ATX Contour 130k w/ a 21k tranny freshly installed
Secret Project in the works
Originally posted by unknown: Never argue with an idiot, ppl may not be able to tell the difference between you.
Posts: 9,602 |
Originally posted by wstang455: Ok I see a nice purty engine compartment and I see the separator, first off it's not a Zetec, second how do you install it on a zetec, third...nah never mind the third.
1.
Why don't you just do your own leg work instead of whining? 2.
The seperator obviously goes into the PCV line between the PCV and the intake. It's up to you to figure out where is best to mount it.
...and just for spite... 3.
2000 SVT #674
Posts: 624 |
Posts: 736 |
Because, whining is fun once in a while, i don't do it often but Occasionally I like to really get on a good whine, so
Posts: 3,290 |
OK, you guys have me convinced to try one of these. Too bad I've already got 75K worth of gunk in my intake  . As I've learned, the PCV system seems to be sensitive to changes (like using a Purolator instead of Motorcraft valve in my case), and if the separator doesn't trigger a MIL, it must not be too invasive.
E0 #36
'95 Ranger
'82 Honda CX500
Posts: 4,899 |
How bad is the gunk in a Contour? In a TDI, it bonds with EGR fumes and coats the intake manifold with a oily carbon mess, along with oiling up the intercooler. Is it just an oily gunk in the contour?
