Whoa!!!..
First off...
Step away... from the CAPS... (Gives a sense of yelling, and an overall "loud" appearance, making it harder to decipher relevant information from your post..)
Firstly:
The MAF sensor can be located be finding your air filter. (In a black filter box.. Just towards the engine, will be a roughly rectanglar box mounted to the MAF(Mass Air Flow).. You should see a small sensor on top of the box, with wires leading to it.. This is the MAF Sensor.
The MAF is the first physical thing, after the air filter...
Secondly.. The Autozone tech will read and "attempt" to tell you what your code means.. He basically reads what the screen tells him to say.. That's about it.. Make sure to grab that code, and post it here, so that those of us with MUCH greater knowledge on the topic will be able to help you out.. plenty of people on here, and a lot of past incidents..
I doubt Autozone will have diagrams, but WE may, if we know the code..
HTH
Ray
