I have had the same problem. It took me about two weeks and new lower motor mounts before I found it. Check you inner CV joint. It depends on which side your feeling the vibration. It might just need to be greased up but if it continues a new axle might be in store. Which the price isn't bad on that as long as you can do the work yourself.
