Posts: 278 |
how would you go about fitting a tire with an 8 or 8.5 inch width?
2000 Silver Frost SVT
resonator removed
20% tints
obx short shifter
eibachs & konis
...more to come...
Posts: 2,127 |
An 8" wide tire is essentially a 205mm wide tire, that is no problem. I have 225mm wide tires for my SVT and just barely rub in the back. That's closer to a 9" tire.
You shouldn't have any issues with a 205 or most 215's
Or do you mean an 8" wheel?
HTH,
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Posts: 278 |
I'm sorry I was meaning putting an 8in wheel(something like anOZ supraleggra 17x8 or8.5)
resonator removed
20% tints
obx short shifter
eibachs & konis
...more to come...
Posts: 2,127 |
I have that very wheel in a 17x7" and I have no problems with 215/45-17's
My stock E0's with 225/50-16's have a mild rub in the back, on the tie bar.
TB
Posts: 278 |
so is an 8in wheel to big? or is there a possible way to make it fit?
resonator removed
20% tints
obx short shifter
eibachs & konis
...more to come...
Posts: 4,639 |
yes 8 inch can fit. i'd get it w/ 45offset and a done up suspension. roll the fenders
Hugo AIM:omegazodiac
Posts: 873 |
Originally posted by hmouta: yes 8 inch can fit. i'd get it w/ 45offset and a done up suspension. roll the fenders
UGGGGG, is there anything more you would like to pull from your brown eye?
Read THIS.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 34 |
Pretty good answer. We'll give you an "A" for the lesson.
Tom
Posts: 4,639 |
Originally posted by Qbert: Originally posted by hmouta: yes 8 inch can fit. i'd get it w/ 45offset and a done up suspension. roll the fenders
Read THIS.
read the original post. he asked how he can fit an 8inch or 8.5 wide wheel. i answered him. no $hit u can run other offsets if u have the time and/or money to make it work. i was giving him a suggestion to get his wheels to fit w/ minimal troubles. if he wants to run a 35 offset 8.5 wide wheel, then good luck. i would gladly love to check out that ride. instead of being an ass why dont u simply state "if willing to search for the right wheel u can (with more work) make other offsets work". i know when i ask a question i like to get as many answers and variable possibilies. or YOU can always pay 2K for a leda suspension for him to run ANY offset that his heart desires. until then, i'll try to give other members suggestions to help them get the results they want will minimal headaches based on countless other members. if he wants to take it a step further, then he can gladly do so. do me a favor and ask everyone w/ 18x8s 18x8.5 or 19x7.5 19x8 on the board what offset their wheels. i'll bet most will be similar, with exceptions bound to exist. i've been on the forums long enough and read and reread countless and countless posts regarding this same topic. so i'm not pulling #s out of my a$$.
Posts: 873 |
Originally posted by hmouta: or YOU can always pay 2K for a leda suspension for him to run ANY offset that his heart desires.
Would you like to enlighten me on how this magical suspension would allow you to run any offset? As far as I can tell there is only so much room between the hub and the strut.
Hey, you've obviously been here longer then I have, you can go try and find someone to prove me wrong, I'll be waiting (probably for a long time).
