Page 2 of 2 1 2
#530345 01/24/03 06:24 AM
Originally posted by MystiqueSVT:
So what is it that requires the SVT to use premium?
Is it the slightly higher compression ratio over the standard V6?
I believe the SVT heads and cam are different, thus creating the .5 increase in compression...correct?
The SVT uses different pistons to obtain the very slightly higher compression. Non SVT is 9.8:1. 98 and 99 SVT is 10:1. 00 SVT is 10.25:1.
#530346 01/24/03 06:28 AM
Originally posted by Rogerm60:
Compression and ignition timing. Cam does not affect octane requirement.
Cams do effect octane requirement. Cams change cylinder pressure due to better breathing. Increased cylinder pressure is what increases horsepower.
#530347 01/24/03 07:09 AM
Stock CR is 9.7:1
The SVT requires higher octane because of ignition timing and cams.
Just the CR alone does not warrant it as the 3L Duratec is 10:1 and uses 87 octane fuel.
Run a stock Contique on 87 octane and an SVT on the highest grade you can get (up to 93)
Chipped, Nitrous, or F/I owners should already know they need to run the best they can find.
Nitrous only needs it when the juice is flowing. The rest of the time it's just hurting performance & mpg in a regular Duratec! (get a flip chip!)
#530348 01/24/03 07:42 AM
E
E
If you use premium all the time you may find better performance (if you drive hard most/all the time)
The engine does have some self adjustment to driving that will give a tiny increase in performance over 87 octane if you use 93 ALL the time. and drive like a bat out of h*ll 90% of the time.
if you drive like a Granny, forget it.
I got a glimpse of a new Nissan Z tonight as I passed it doing 85mph in a 50 zone on the freeway. They were doing somewhere near 50'ish... Too bad, such a cool car to do just the speed limit in
A Contour? HAh HAH ha HAh ha hah hah ha ha....
Page 2 of 2 1 2
