Posts: 92 |
Its been cold here in Ottawa, Canada the last few days.today's high is -20 C which I think is about -4 F. My gas pedal was stuck at idle yesterday after work .I applied a small amount foot pressure and got no response. A vigorous shake up and down by hand loosened up the pedal and I was good to go.This has occured 2 out of the last three days. Has anyone out there experienced this same problem and/or know why its happening? Coincidently, after the first incident, my automatic shifter also has loosened up back to normal. It had been stiff to select from Park to Drive or Reverse and back to Park, although the transmission has worked fine.
stock 95 LX,6cyl ATX
98.5 wheels with Yokohama AVID T4's
Posts: 3,506 |
The only time I experience that is when the heater is on high and you set it on the floor.And then I have to Floor is all the way.
This happend to me in my dads old contour with an ATX...I have a MTX and no problmes.
I know its a long way off, but try it on a semi warm day and put the heater on full....If it sticks then thats the problme. Weather its a actuall "heat" or temp problem I don't know. I could be something sticky or something that has to do with the computer.
Roz
