Posts: 1,785 |
Mine are 7.5 inches with 42 off set
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 873 |
Originally posted by myfastse: Mine are 7.5 inches with 42 off set
Yep, which gives you 5.4" of backspacing.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 346 |
Originally posted by Qbert: Originally posted by hmouta: i'm talking about our cars, not all cars.
Yeah, I was also talking about Contours. Trust me, 90% sure that you won't be able to get an 8 inch wheel with at 45mm offset on the car, well not with a tire anyway.
I am a 100% sure you can.  I ran on 19x8 45mm offset Axis Sevens with no rub at all. Granted the tire was only 215mm wide. Oh yeah. I am dropped 3" sometimes with coilovers.
Posts: 873 |
Originally posted by lilbern: Originally posted by Qbert: Originally posted by hmouta: i'm talking about our cars, not all cars.
I stand corrected then.
BTW, you stated in another post that you were rubbing with 7.5's with 225's on them. Where were you rubbing at, inside or out?
I was assuming 225's would be used, but I was still almost positive 215's wouldn't fit, they must be extremely close to the strut.
Posts: 346 |
I rubbed like a mofo on the outside lips. Just beat the hell out of them and went on my merry little way. I was just barely missing the strut when I had the Axis on. I have more room with the Centerlines on because the offset pushes them out more.
