Highly Medicated Member
Posts: 2,882 |
I am running 17 x 7 (37 offset) zero problems
I am considering going to a 17.7.5 (35 offset) any feedback?
I'm on H&R with stock struts now, but will have Konis for the new wheels.
Mark
EDIT:
ive read back through 10 pages of dialogue. It seems that this wont work, ~40 is the lowest people say, yet I am running 17 x 7 (37offset) with out issue on my OZ SuperT's? Will the 2mm cause me a problem? I've also looked under the car, but realized I had my winter set on, doh! Also, I have lightly rolled my lips. I could roll a bit more if needed.
Looking for input in a time sensitive issue. TIA...
Semper Fi
"They've got us surrounded. Poor bastards." -Chesty
Posts: 11 |
OK: 7" and 37mm offset means 125.9mm or 4.96" of the wheel are inside the mounting surface. ((7in x 25.4mm/in) / 2) + 37mm = 125.9mm Therefore: 7.5" and 35mm offset will mean 130.25mm or 5.13" of the wheel will be inside the mounting surface. ((7.5in x 25.4mm/in) / 2) + 35mm = 130.25mm Do you have an additional 5mm clearance between the tire and strut tower? If not you'll need 5mm wheel spacers. Be sure of this - see my posts under, "Help! My Tires Self Destructed." I am looking at adding 15mm spacers just to be sure. Original E1 wheel: 6.5" and 40mm give 122.55mm My Alba Blaze: 7.5" and 42mm give 137.25mm 137.25mm - 122.55mm = 14.7mm 15mm = .59" or between 9/16" and 5/8" I'm hoping they don't stick out too far...  Martin
99 Silver Frost SVT
205/55x16 Goodyear Eagle F1 GS-D3's on stock E1's
EBC Sports front rotors
EBC GreenStuff all around
Pioneer DEH-P3000 AM/FM/CD
4 Pioneer TS-A6813
Sylvania SilverStar 9006 lows
Sylvania 885 50W fogs
DRLs
Posts: 2,127 |
I'm not sure if Martin did all of his math right, but he has the right idea. So peep this page http://www.tirerack.com/wheels/tech/offset.htmLet's see what I can come up with. Off to play with Star Office a bit. TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Posts: 2,127 |
I've plugged in a few numbers and with your 37mm offset I get the following on a 7" wheel
Width outside the hub = 51.9mm
Width inside the hub = 125.9mm
If you go to a 7.5" wide wheel with a 43mm offset, I think you get 52.25mm outside the hub and 138.25 inside.
Staying at the same 37mm offset, but with a 7.5" wheel nets you 58.25 outside and 132.25mm inside the hub.
I dunno which way you need to go though.
TB
Now hopefully with math errors corrected
Posts: 11 |
Yes, I did the math right. Yours is obviously wrong.  Your numbers don't add up: 140.8mm outside the hub + 214.8mm inside the hub = 355.6mm which is 14"! He is talking about 7" wide wheels not 14" wide. Martin
99 Silver Frost SVT
4 Pioneer TS-A6813
DRLs
Posts: 2,127 |
You are right, I found I missed the division by two. I was just curious how you got the same width on both sides with a non-zero offset. I'll edit my message above, if I still can.
Thanks,
TB
(EDIT: Never mind, I misunderstood your original message. I'm glad I'm not working any service calls right now, I can't even understand basic english or math.)
tb
Posts: 3,867 |
Check your entering arguments. I don't think 40mm is the stock offset for the E1 wheels. Somebody said 49.5mm the other day, but I don't have first hand knowledge, here.
As for me, I'm running 7.5" 16's with 43mm offset, and I'm OK. HTH.
Function before fashion.
'96 Contour SE
Posts: 11 |
40mm is the offset for the stock 16 x 6.5" E1 wheel. The 17 x 7" Focus SVT wheel has a 49mm offset.
If the E1 wheel was 49mm I would have had no problems with my 18 x 7.5" wheels with a 42mm offset.
Martin
99 Silver Frost SVT
4 Pioneer TS-A6813
DRLs
Posts: 3,867 |
OK. Thanks for clarifying.
'96 Contour SE
Posts: 873 |
Originally posted by mhconley: 40mm is the offset for the stock 16 x 6.5" E1 wheel. The 17 x 7" Focus SVT wheel has a 49mm offset.
Martin
The stock E1 wheel is stamped with 49.5mm, if I get over to where my race tires are stored today I'll take a picture for you.
And yes you still would have a problem with your 18x7.5's. Think about it, if the stock 6.5" wheel has a 49.5mm, a 7" wheel should be right around 43mm offset to keep the inner dimensions about the same, so a 7.5" wheel whould need something about 37mm or so.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
