My car vibrates a little at high speed. Had my car balanced twice no problem with tires. Had my left side cv axle replaced beacause it used to shake. What could be the definate reason? I also need to replace the lower ball joint control arm because the ball joint is dried out. I get most of the vibration from the steering and it increases around 70 - 90 mph and it goes away at higher than 90 mph.
96 Contour 2.5 V6 atx 122500 miles
