Posts: 3,774 |
I used the right blinker this morning and it is blinking double-time. What's the deal with this? Is it stuff in the "halfway point"? Can I fix this myself.
Any help, thanks,
Brian
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 3,419 |
bulb out on your right side, check front and back
Posts: 1,861 |
If it is just one side that is usually a sign that one of your bulbs has burned out. Check your turn signal bulbs. It seems that the rear bulbs are more prone to failure than the front ones.
If it is both sides and the bulbs are OK, have a good look at the turn signal switch. This can happen when the contacts get worn or dirty. You may need to replace the switch. Sometimes you can resolve it from pushing the button rapidly on the 4 way flashers as well as repeatedly turning the turn signals off and on to clean the contacts. Make sure that the button for the 4 ways does not stick part way between off and on.
Jim Johnson 98 SVT
Posts: 3,774 |
cool! i'll check it out.
thanks.
Posts: 586 |
Had that happen to me a couple of months ago. The back bulb was burned out. Cost me a whole $1.50 for two bulbs.
Ed
Posts: 5 |
Definately a burned out bulb, happened to me on the right side.
Posts: 3,774 |
replaced bulb today.
problem solved.
total cost : $3 (had to buy a pack of 2 bulbs)
Posts: 3,165 |
Just an FYI: If you just barely hold down/up the signal lever w/o clicking it into position it blinks too. Anyways, my point is that sometimes when you don't press on it firm enough and just lightly press it down/up, the blinker goes double time then too. :p
