Page 2 of 2 1 2
#527471 01/22/03 03:56 AM
Neither do I.
There's no way you're gonna have a "comfy" ride with a 19" whell combo. The damper stiffness required to control the rolling stock means the ride has to be VERY stiff to feel right, without any harshness or bouncyness.
I don't even feel that maxed-out Konis are enough for such a crazy drop. It's not the damper's fault, but the car is 1/2" away from the bump stops at that drop, and it comes in contact with them at every occasion.. so on and so forth....
I can go in VERY deep detail and bore you all out of your brains on specifics regarding the design of my Leda setup. Let's just say for starters that my damper's bodies were 2" shorter than Konis. There's more...
#527472 01/22/03 04:12 AM
Bernie
I love you wheels. Can you get a 47mm offset with those wheels. If not will i still rub with 215/35?
#527473 01/22/03 12:38 PM
N
N
How does the VW Ride? What suspension are you using?
#527474 01/22/03 06:18 PM
My VW's ride is very tight. No aftershock, no bounce-back. No initial harshness either, but that's something most people have a hard time quantifying. It's ALWAYS in control, and that's the most important thing. If I get the car airborne when it lands I want NO second bounce, it needs to settle immediately. I do get it airborne.
Suspension is Bilstein PSS-9 coilovers. 9-point adjustable compression damping (with rebound tied into it), with linear springs in the front and a progressive spring in the back. Upgraded anti-roll bars front and back, upper strut bars front and back, lower stress bars front and back and polyurethane bushings on all links and pivot points. Combined with VW's tight unibody it makes for a very interesting car to drive.. personal taste of course, wouldn't suit most people.
#527475 01/29/03 06:07 AM
H
H
Originally posted by JiggaJerry:
40mm offset is what you should always use
wrong. see the other post or two for offsets. i just answered them.
i WISH the bilstein pss9 setup was made for our car. when i first found out about them, i was pissed we weren't included.
anyone think there's any chance of having them made if we can get a big enough group buy.
#527476 01/29/03 06:53 AM
Q
Q
Read THIS...I think you may be wrong.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels 1/4 mile - 15.201@89.4mph
#527477 01/29/03 01:19 PM
N
N
anyone think there's any chance of havingm made if we can get a big enough group buy.
This would be great if we could get them made for our cars i would definetly buy
#527478 01/31/03 07:18 AM
H
H
how exactly am i wrong. jiggajerry said to always use 40mm offset wheels. he used the word ALWAYS. so if i'm wrong then EVERY contour on this site is supposed to run 40mm offset wheels. i think we both know thats not correct. uh, thats sounds pretty wrong to me.
#527479 01/31/03 09:57 AM
Q
Q
I was talking about you stating 45mm offset was the way to go. If you read my other post you would have noticed that I stated the E1 wheel was 49.5mm offset
#527480 02/01/03 04:44 PM
ok mine are a 45mm offset and i havent had any problems with rubbing until i load the rear end down them the passenger rear will sometimes bottom out and rub but i have no rub as of now, but i plan on dropping it in a month or so so i think i might have some then.
1999 SVT #336 Tropic Green 19" Axis Se7ens INJEN intake OMP Strut Brace HPP Rear Brace B&G Drop www.cardomain.com/id/svtpyr8
Page 2 of 2 1 2
Moderated by  1314_dup1
