Page 1 of 3 1 2 3
Recently i have noticed my battery light flickering when i am flooring the car. I do have a system, but it still does it when the system is turned off. Also of note is that my car has been less powerful than it should be, for example, an se modded slightly more than i am was able to pull on me. Is my system causing this, or are my old wires maybe not insulating correctly? I have no idea what could be wrong. Thanks
98 3.0 svt: Sold
O
O
i,am having the same problem!I,ve changed the altenator and\
belts and still have problems!let me know if you find
something
New Pics of OUTKAST 1!Sept2006
Where di you get the alternator from?? I got one from Pep Boys and it was bad from the time I installed it.
98 SVT 18" Enkei RS6's, NITTO 555 Extremes Intrax lowering springs K&N filter Sho-Shop Y pipe (without cats) Stock "gutted" manifolds Carbon Fiber Cowl hood Carbon fiber sail panels
O
O
two pro plus alternators and one dealer !
U
U
I have the same problem in my 1998 Zetec Contour. I just replaced the Mega fuse as per recomendation from another post. That did not help the problem! Arrg. Anyone have an answer? Alternator cuts out at high RPM? Just a thought.
Please help.
Chris in Buffalo
O
O
please help!!!I hate the ford jokes at work!so I have to
fix this problem!let me know what you find..
I have the same problem with my 98 zetec!! And I removed both the alternator and the battery and took them to Autozone and got them tested. They tested fine, so I am out of ideas. I also removed my mega fuse and it had no signs of being bad and I tested that and it was fine also. The guy at autozone said that they only test the alternators at like 2000rpms and mine might be cutting out at higher rpms...
98 T-red Contour LX Zetec (100k miles) 98 T-red CSVT (40k miles) 18" Enkei Rs5's Pioneer Premier 740 12" Rockford HE powered by 420 watt amp C27 Front Fascia
you have a ground wire disconnected somewhere would be my guess...but first and formost...change the battery cables. them PM me and we'll decide where to go from there.
95 GL MTX Zetec, Carbon Fiber hood: *neoprene seat covers *new SVT rear bumper *Proud Owner of 1962 Chevy Corvette 427
that smiley was supposed to be at the end of that sentence...
Faulty alternator! Most likely the regulator is suspect.
Most "rebuilds" try to use the original voltage regulator to save money. The regulator is the #1 cause for failure. Unfortunately it fails first as you are describing. At high rpms under load. Followed by total failure.
Most rebuilders do not test their products to those conditions. Just under normal cruise conditions at a preset load and call it good.
I do know that Worldwide Products does. Each alternator they sell comes with a data spec sheet that shows the alternator's output plotted on a graph from 0 to 7000rpm plus.
Autozone & Advance carry this brand. Other's may as well???
NAPA, O Reilly's, Pep Boys, & CarQuest I know DO NOT! (Not that I'd even send an enemy to 3 of those places! NAPA's okay if you can get past their outrageous prices!)
Page 1 of 3 1 2 3
