Posts: 32 |
So for Christmas, I recieved the Pioneer 220 watt speakers that are epecially made for Contours. Well, they sounded nice, but I knew they could do better. So yesterday (I was in an extremely bad mood, since I knew I couldn't afford it), I bought a Pioneer DEH-P4400 that is 50x4 watts. I finally got it installed and it sounds like Sh--. My factory head unit sounded better, I don't understand why this one sounds bad. I was thinking that maybe I need to byass the factory amp, but the guy at HHGreg said that I shouldn't need to because he installed a custom stereo in a Mustang without bypassing the amp, and he said it sounded great. Soo..... did I waste $200. on this stereo.... should I return it and just use the factory one?? Advice please... thanks....
Jonathan
Posts: 972 |
Uh, that guy sells stereos for a living?  When you amplify an amplified signal, it will be very distorted. by-pass that amp and it will solve all of your problems.
95 SE Modded - Gone
98 E0 Black SVT - Gone
98 se sport - Broken
00 T-Red SVT - Nice
Posts: 100 |
let see lets say F... the guy that told you not to stangs and contours arent the same car made by same company but aint the same car I would truste him if he said he installed one in a contour but he didnt plus all new stangs are sh.. so oh well I am sure that it wouldnt cost to much to bypass the amp
Posts: 32 |
Originally posted by bennyboy02: ...I am sure that it wouldnt cost to much to bypass the amp
$13. But I guess after $200., it isn't too bad.
Posts: 9,442 |
Try http://www.crutchfield.com for the amp bypass harness. I wouldn't take my car back to that guy if i were you.
Posts: 569 |
I wired around my factory amp myself. Didn't cost much I think like 5 bucks and didn't take long once I fugured out the wireing.
....Brad
Your mom thinks I'm hot!! But my wife rocks!!
99 Mestique Zetec ATX, 96 4Runner 5speed
Mods? Um gotem.
VFA-94VFA-122 VFA-115
Posts: 1,247 |
I got the same headunit. I never bypassed the factory amp and it sounds fine to me. Somebody told me at best buy and circuit city that if i don't bypass it, I can burn out one of the amps (factory and internal amp in headunit). I don't believe that. They're just trying to make money that's what I believe. I bypassed it and it's not as loud so i took it back. If you hook up an after market amp, you're still running both amps. What the hell is the difference? That's why I kept it like it is.
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 644 |
you just can't compare ANY aftermarket amp with the piece of sh!t factory amp in the Contour. Have you ever seen an aftermarket amp as small and light as the one in our cars? Come on, it's junk...
Why would you want to amplify an ALREADY amplified signal from your head unit? You're simply adding distortion... PERIOD. If you want to use an amplifier, you must run PREAMP outputs from your headunit, or get an amp that has speaker level inputs... and the factory amp DOES NOT HAVE speaker level inputs. You WILL burn it out!
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 974 |
I just want to clarify that if you use an aftermarket amp with a aftermarket HU you are not using both amps (your HU amp and your aftermarket) you are only using the aftermarket!
Posts: 2,469 |
If you need an amp bypass harness send a self addressed/ stamped envelope and you can have mine. I have a 4ch amp powering my speakers so i dont need it anymore. pm if you want it. And yes it will fix your problem.
