#52609 01/31/02 05:26 PM
Davin Offline OP
Got the car back from the dealer and ever since I have a fast right turn signal. What could be causeing this?
Jesus is Messiah
95 Contour GL 24v
#52610 01/31/02 05:27 PM
E
E
Check your bulbs. When one of the bulbs blows, the other one on the same side will blink faster.
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
#52611 01/31/02 05:36 PM
yea, happened to me when I ran over a speedlimit sign laugh
STD's are like Pokemon...
Gotta catch em' all!
#52612 01/31/02 07:09 PM
Davin Offline OP
Thanks guys, would it me the opposite turn signal or could it be the headlight?
Jesus is Messiah
95 Contour GL 24v
#52613 01/31/02 07:14 PM
Not headlamps, the lights that blink with your turn signal. Check front and rear signal lights on the side that blinks like it is on meth. Better than my old VW which just went solid when that happened. :rolleyes:
#52614 01/31/02 10:26 PM
same here. that happened and noticed my brake light was out....... smile
#52615 02/01/02 04:56 AM
took me awhile to first figure that one out too...the fast blink turn signal when i first got my car....old skool cars when u hit the signal would just light up the turn indicator on the dash but would not blink at all and the taurus i had would tell u exactly which bulb was out
replace the bulb or bulbs since they're cheap and come two to a pack
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#52616 02/01/02 11:29 AM
Davin Offline OP
Hmmm. Mine is ok sometimes and then hyper other times. Maybe it is just not properly seated
Jesus is Messiah
95 Contour GL 24v
#52617 02/02/02 12:36 AM
i dont think its how the bulb is seated because of the little nubs to hold it in place...they're pretty snuggly fit
when my first signal went out it started out the way u described above...hyper sometime then okay...i thought i had bought myself some new electrical problems ... but it was the bulb...
when the second one started getting hyper i just immediatedly replaced it...no mo issues
#52618 02/02/02 04:38 AM
E
E
Mine was lighting the dash indicator last week. It turned out that the little nubs that power the light wern't tight enough. Luckily it was on the side of the car that has the broken lens, so it was an easy fix. smile
Probably the easiest way is to turn the hazards on and walk around the car. Starting with the side that blinks too fast.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
