Posts: 129 |
Got the car back from the dealer and ever since I have a fast right turn signal. What could be causeing this?
Jesus is Messiah 95 Contour GL 24v
Posts: 1,859 |
Check your bulbs. When one of the bulbs blows, the other one on the same side will blink faster.
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent* Please call... 1-800-FOR-ELKY
All proceeds go towards saving CEG
Posts: 3,066 |
yea, happened to me when I ran over a speedlimit sign
STD's are like Pokemon... Gotta catch em' all!
Posts: 129 |
Thanks guys, would it me the opposite turn signal or could it be the headlight?
Posts: 3,419 |
Not headlamps, the lights that blink with your turn signal. Check front and rear signal lights on the side that blinks like it is on meth. Better than my old VW which just went solid when that happened. :rolleyes:
Posts: 2,809 |
same here. that happened and noticed my brake light was out.......
Posts: 1,445 |
took me awhile to first figure that one out too...the fast blink turn signal when i first got my car....old skool cars when u hit the signal would just light up the turn indicator on the dash but would not blink at all and the taurus i had would tell u exactly which bulb was out
replace the bulb or bulbs since they're cheap and come two to a pack
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 129 |
Hmmm. Mine is ok sometimes and then hyper other times. Maybe it is just not properly seated
Posts: 1,445 |
i dont think its how the bulb is seated because of the little nubs to hold it in place...they're pretty snuggly fit
when my first signal went out it started out the way u described above...hyper sometime then okay...i thought i had bought myself some new electrical problems ... but it was the bulb...
when the second one started getting hyper i just immediatedly replaced it...no mo issues
Posts: 3,934 |
Mine was lighting the dash indicator last week. It turned out that the little nubs that power the light wern't tight enough. Luckily it was on the side of the car that has the broken lens, so it was an easy fix. Probably the easiest way is to turn the hazards on and walk around the car. Starting with the side that blinks too fast.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
