#525711 01/17/03 09:40 PM
W
W
Ok, I am going to go with true duals. I want to know if my design would be good or if I should try to copy some elses.
Here's what I was thinking:
Cut the stock y pipe and make two pipes out of it. Then bolt this high flow cat: Dual IN/Dual OUT Cat
Then finish the job with dual mandrel bent piping to the mufflers in basicly the same position as the stock ones.
One question though; will I want resonators?
Will replacing the stock mufflers be a good idea and what mufflers should I replace them with?
Also I was going to get the mandrel bends from jcwhitney. Anyone found a better place?
2FAST4U 2000 Contour SVT
#525712 01/18/03 01:18 AM
Highly Medicated Member
I don't know if my variations will translate - I have done 2in/2out mufflers, but not a cat. I have been unhappy with a 2in/2out arrangement. Largely for noise, but I believe low end and mid range performance has suffered as well. No proof though. I suspect there would be a better way, but you won't know if you don't try.
If you must preserve a cat, perhaps try 2 separate smaller ones and do not cross lines.
This is a new one for the CEG. Anyone else got any thoughts?
Mark
Semper Fi "They've got us surrounded. Poor bastards." -Chesty
#525713 01/18/03 05:01 AM
Very much so!
Mingling the exhaust gasses basically negates having separate pipes! Maybe even to the point of being worse then a tune Y-pipe setup???
Shared mufflers and/or cats are garbage!
Use only straight through mufflers (no baffles or twin pipe cores) with a perforated core (no louvered core!)
#525714 01/18/03 06:29 AM
its seems everyone is taking the initiative to do there own true dual set up . You think yo-dude could have put something together by now ... caugh groupbuy cough
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
#525715 01/18/03 07:25 PM
W
W
I read the posts for the groupbuy and honestly I can't see paying $700 for duals.
I found the piping from jcwhitney for under $100 (for the mandrel bends that are needed for duals).
So basiclly that dual in/ dual out cat sucks? Are there better brands of cats? Do I just need to make sure its super flow cats?
I found high flow cats on ebay for $50. Are these ok?
Bomz Cats
or these?
Car Sound High Flow
#525716 01/19/03 06:57 AM
Summit sells good cats for a good price.
http://store.summitracing.com/partdetail.asp?part=18587
