Page 3 of 3 1 2 3
SVT CT....any of those will work because they are all 3.5 inch flange...which is the same as the bat/mirko/etc maf adapter
Some people want a higher flow filter...the 3130 flows almost around the rate of the kkm....
If you have an svt I would go one of the ones I mentioned,
Might rub the hood a lil cuz its a big filter
http://home.kc.rr.com/newshore/Cars/N-E-Bay4.jpg
Actually, if i remember correctly, the E-0998 is the filter that fits a stock SVT airbox. Not the same as a regular Contour air filter which is a drop in square (flat filter) K@N 33-2115-1 . E-0998 does not have a flange, and is a pressure fit inside the conical SVT air box. Although it is a conical filter it can only directly replace cars with SVT air boxes, not stock Contours
Below is a link to a list on the the K@N web site that gives the dimensions of all the filters.
The RU-3130 is a conical filter with a flange.
http://www.knfilters.com/universal/univrndtap.htm
Go through the list, and base your choice on dimentions of your intake...in my case, I use a RU-3130 since that's what fits the diameter of the Mirko racing intake.
Let me know if you need anything else.
99 SVT (Black) # 2642 of 2760 So Many Mods...So Little Time!!
I don't think the 3130 is to small my car has never felt like it was running out of air. But one of the bigger ones certinatly wouldn't hurt. I am sure you can find some pictures of peoples cars with the open filters and see how they seem to fit. The 3130 fits very nicely with a heat shield.
Green 2000 SVT #1166 mods-K&N and Custom heat shield, optimized y pipe, Magnaflow center resonator, DMDhttp://www.geocities.com/savinoss/Cars.html -Wifes car 99 Mystique V6 5 spd
SVT_CT Offline OP
thanks for all the help!
99 Silver CSVT #1081/2760 97 Nissan Altima 83 Corolla SR5 RWD bondo/rust body 'ghetto cruiser' RIP 78 Winnebago Minnie (Dodge Chassis 23') 440cid 4bbl.
Page 3 of 3 1 2 3
