showngo Offline OP
anyone know how to remove a cigar lighter from a 98+ center console?? i've done my best not to break it, but it looks like it's kinda tough. help!!!
#1000 of 2760 Money talks, it says good-bye!!! 19's are here...
The only way I know how is when I had the console out...It just kinda is clipped in there. But on yours being the new console, I don't have a clue...
silly question, why? i don't smoke but i use mine to plug in my phone charger, can these be switched into AC adapters? that would be cool.
"What did you think about that Dorothy girl?" "The whole Judy Garland thing kinda turned me on. That doesn't make me some sort of fag does it? "Nah baby, your money." 98 Black SVT #3560 of 6535
I happened to have just worked on that the other day. My problem was that it got pushed INDSIDE when I was plugging in.
You have to take off he screws on the left side of console and the screw on the right, closest to the firewall.
Then, pull the console far enough to stick your left hand inside of the console housing. Reach all of the way to the lighter and there are two wires that are attached to the lighter. Gently pull the wires out and then hold the lighter housing and start unscrewing while at the same time, use your right hand to hold the ring in front while your are unscrewing. It is actually two pieces. Do you plan on putting the lighter back?
Good Luck
98 SE Duratec/MTX Plain Jane (for now) 98SVT #231/6535 Stock www.pbase.com/ddehoyos/svt
My question is, is there a fuse inside the adapter itself? I blew mine...well it wasn't a cigg lighter. It was just a power out let and well my girlfriend put a kragens cigg lighter in there and it blew it.
Any thoughts on the fuses or might i need a new one.
Roz
They are usually a buss fuse and it's in the adapter. I was a dumba$$ the other day when I blew mine. I bought a 3 plug multi adapter a few weeks ago, (radar detector/phone charger). Then I bought a 100 watt power inverter and it said, clearly...do not plug inverter into multi plug cig outlet, what did I do? Not only did I blow the multiplug fuse, I als blew the 15amp fuse on the fuse box
but why remove the lighter? for repairs? does it add hp , and if so how much? i have that playstation with the screen for my son but the plug doesn't fit into the cig lighter, can it be replaced with a diferent size or something?
Apaarently our cig lighters are very tight. My inverter barely fits, it's very tight. You might have to put the pliers to the PS plug to fit,
showngo Offline OP
i got it out and only broke 1 clip!!! go me....to answer the question, i use my car charger for my phone. however, i am also in the process of installing a power inverter for AC devices also.
mmmm, more power... So are ya doin' what I think you're doin' and swapping consoles too?
