I
I
hey guys just so u know i searched this already and came up hopeless...i hear a slight squeaking sound on the drivers side tire...only comes when i hit bad bumps(which i try to go around-nj sux) but still it is annoying..now when i got my tires rotated and sprak plugs changed, the guy told me it might be the bushings...what do u guys think, and also how can i go about fixing this..any info would be great...or could it be something else...help!!!!! frown
Chris
99 V6 Sport/Silver
SVT kit~SVT Dual Ex.~KKM intake~Front & Rear grills painted silver~GTS Headlight covers~Plasma Blue light under dash(removed white bulb)~30 % tints~Tinted Rear Reflector~Wood Grain Kit~Removed door dings~Super White Heads~Plasma blue reverse lights~ blacked out sail panels~painted brakes Blue~complete stereo system~
On a 99, I would get the undercarriage of the car washed,
and then spray the bushings with a Silicone Spray.
They should not be worn, where they need replacement.
Just probably squesking from the Road Salt.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
I
I
ok cool thanx...how should i spray it...are there any places where i might spray and do some damage...
Chris
99 V6 Sport/Silver
I had a similar squeaking but only when i hit bumps. Mine car is a '96 with 157,000 kilometers (95,000 miles). The noice was caused by wear to the bushings on the front stabilizer bar which I replace at a cost of $200 CDN. No more squeak!
Could be control arm bushings or stabilizer bar bushings. Maybe even the strut spring rubbing. Silicone won't harm anything, its pretty inert.
Dan B.
I
I
thanx guys....by the way do u know where i can get those bushings...like a good company...thanx again...
Chris
99 V6 Sport/Silver
well you can go to your local dealer and buy the bushings there. They should be in stock since worn bushings are common. Or go to your local aftermarket parts supplier like napa, pep boys, etc. Or you can go aftermarket and pick up a set of urethane bushings, they are a little pricier but will result in slightly better stability in cornering.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
Squeaking is from the sway bar bushings (best to replace them) and front A arm bushings rattle. I speak from experience.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
I have the same problem with my car it squeeks every now and then somtimes it is really bad it even squeeks while turning left or right. The noise is coming from the driver side. I took the car to the tire shop and they told me I have to replace the whole left side sub frame. Would it be neccessary to do the right side as well. Does this worn dried out lower ball joint cause any vibration at high speed because I had the tires balanced and my cv-axle checked and it is fine and I still get a little vibration on the front dash and steering and also on the seats as well. If I replace my lower ball joint assembly will this cure my vibration.
I
I
great info guys i appreciate it...ill have to get to it very soon....and also i have a lil vibration sound when i drive on the highway too...i just had my tired balanced so maybe its that ...oh well ill have to see...thanx
Chris
99 V6 Sport/Silver
