Posts: 259 |
I feel it off the line more and topend..... I like it...
Posts: 392 |
You should try to talk Bosal into making headers for the Contour. Preferably, headers that are emissions compliant without any M-I-L eliminators. I think they would sell well if priced in between the overpriced SHM headers and the MSDS headers. I would volunteer my car for test fitting!!
1998 SVT
Posts: 259 |
Originally posted by Baby SHO: You should try to talk Bosal into making headers for the Contour. Preferably, headers that are emissions compliant without any M-I-L eliminators. I think they would sell well if priced in between the overpriced SHM headers and the MSDS headers. I would volunteer my car for test fitting!!
I already inquired about that..... I asked Bandit and he said he doesn't know. are the Probe GT engines the same as ours?????? i know they are 2.5l... i wonder if their headers would work with ours???
Posts: 43 |
The Probe V6 headers will not work, totaly different engine, as far as making headers for the SVT,it would take to much time & money to make such a limited run. It would also be expensive.
Posts: 101 |
Originally posted by Chris Hightower: BANDIT,
I see that the pipes are mandrel bent. Kudos! And the flanges look nice, too.
I would like to know what the I.D. of the pipes are. If they are 2.5", they would be perfect for the turbo setup, or even supercharged.
If the Bosal system is 2.5", you can count on my purchase.
-Chris
just want to make sure. This is a $500.00 exhaust system 2.25 all stainless & replaces everythig from the cat back. Gee I didn't think it would be this hard to do a test fit.
I was hoping it would be 2.5 also. Do you know the weight of this system vs. the stock svt?
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
Posts: 43 |
Stan, I made a mistake, the res & intermediate pipe are 2.5" diam then after it y's off to the 2 rear mufflers it goes down to 2.125". The system weighs around 40lbs.
Posts: 1,603 |
Originally posted by BANDIT: The Probe V6 headers will not work, totaly different engine, as far as making headers for the SVT,it would take to much time & money to make such a limited run. It would also be expensive.
The headers would fit other Contours as well, not just SVTs.
This exhaust should bolt right up to an SE also. I've got an SVT Exhaust hanging on my SE SPort, and all I needed was the Right Rear Muffler Hanger. There are plenty of other Contour Owners who would buy your exhaust kit, Y pipe, Headers, and high flow cat, if you made them matching.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 43 |
What dia would you want the "y" pipe to be?
Posts: 101 |
Originally posted by BANDIT: Stan, I made a mistake, the res & intermediate pipe are 2.5" diam then after it y's off to the 2 rear mufflers it goes down to 2.125". The system weighs around 40lbs.
sounds good,looks real nice in the pics. I still have not put on my headers that i bought about 3 and half months ago.The two combined would give a nice increase in power that i need.I need to think about getting this system. Stan
Posts: 1,603 |
Originally posted by BANDIT: What dia would you want the "y" pipe to be?
The Y pipe would have to exit at 2.5" dia, to connect to a 2.5" IN-OUT Hi Flow Cat, but off the headers, I don't think it should be bigger than 2.125 - 2.25". Any bigger and you may lose necessary backpressure.
The trick is to get the "Y" just right, so that the two pipes aren't CRUSHED together like FORD's Y pipe is.
Pete...
DOB 10/31/2003
DOP 1/2/2004
