Page 2 of 2 1 2
Originally posted by APT CSVT:
Vifa's are currently powered off the factory HU until it gets warm enough to continue working on the stereo. So, it is hard to judge. You were right, more bass than I expected. Not as defined depth and clarity as my Contour setup was with some Audax mids. But, I have a feeling more headroom will fix that.
I have a pair of those Peerless drivers in my RX-7 in the back. I need to put some crossovers on them (high and low), though. That whole setpu needs some crossover help so I reserve judgement on them. I also have another pair of them I was going to use in the rear of the above truck, powered off the HU. But I figure I'd run int othe same problem now with the RX-7 so I may just turn them off with the fader. Anyway, I read your post on these guys and with my limited experience can recommend, especially for the price.
I've got a pair of the old PE crossovers pying around still. Maybe I can sell them to Stazi along with making two 6x8 baffle boards for $15/pair. That is if he doesn't want to spring for the $30 PE ones.
APT
Sounds good, and I might just mount the tweets up high on the side window defroster covers.
Stazzi I mounted my infinity's in the sail panels, flush mounted. I had to break the plastic defroster things to get them to fit and although they look great I can't defrost my windows very well anymore. Anyhow I will take some pictures of it soon and post them for you to see if you would like.
99 Mystique LS T-Red ATX Duratec Mods: Hella stereo Mods K & N air filter w/intake pipe www.sounddomain.com/id/jongordo8
I was able to get my tweeters flush mounted in the defrost covers. Gotta watch the depth and diameter as there isn't much room with the placement of the screw.
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
