#5208 03/16/02 02:08 AM
Danny Offline OP
I did a search but didn't find a definitive answer. I'm going to change & flush out the coolant and am not going to switch over to dexcool. Not yet at least. Anyway, can I use any brand of the green type or does anyone have a specific brand? Thanks.
2000 SVT
Black & Blue
#205 of 2150
Kenwood Head Unit
2001 SR5 4 Runner 4x4
#5209 03/16/02 04:10 AM
you can use any name brand "green" coolant that they carry at your local auto parts store. They're all about the same. I'm going to be using Prestone on my car.
#5210 03/16/02 06:13 AM
Flush the system with fresh water (twice)
Then fill it with mixed "dex-cool" (distilled water a plus) at about a 60/40 water/coolant mix...
Far superior than the old "green stuff"
2000 SVT #674 - Check it out!
#5211 03/16/02 02:45 PM
If you want to stay with the factory green coolant, the Motorcraft stuff is supplied by Texaco. You can often find the Texaco coolant in parts stores. Last I kenw, Wal Mart even carried it.
Personally, I use Texaco's DexCool. Texaco supplies both Ford and GM with DexCool for factory fill.
Jim Johnson
98 SVT
#5212 03/16/02 03:33 PM
What is the difference between "Dexcool" and the green type confused
99 Black&Tan SVT #308 - For sale
Borla Catback, K&N
Blaupunkt
'01 Audi S4 Avant yeeehaa!!
91 Audi Coupe Quattro- For sale
68 Mustang Convertible (summer fun)
#5213 03/17/02 05:16 AM
Both are etheleyn glycol based. The difference is in the additive package. DexCool uses organic acid technology (OAT). Green coolant uses phosphates and / or silicates to provide anti corosion protection. Both are actually somewhat abrasive and will eventually destroy water pump bearings and seals. Silicates also will eventually fall out of suspension leaving the system unprotected. Phosphates will combine with hard water to leave deposites. Europe has more hard water than the US, so european automakers usually specify coolant that is phosphate free. Green coolant will aslo in time become acidic which is harmful to all of the cooling system including seals, gaskets, and metals. OAT has more resistance to becoming acidic, does not fall out of suspension, is not sensitive to hard water, and is not abrasive to seals and water pump bearings.
That is what I have learned from research. There is a lot of controversy about the compatibility of orange and green coolant. It is better that they are not mixed. Some claim that the two will react and cause damage, while Texaco claims that all that happens is that you will no longer have the long life property.
DexCool works for me. I have been in the habit of changing coolant once a year so green coolant might be OK, but I have used DexCool on the SVT since it was a year old (it is not 4 1/2). I use DexCool on the car it replaced since shortly after DexCool was introduced. Radiators do not gunk up, coolant doesn't turn acidic and rot out cooling system parts, water pumps last longer, hoses do not get crusty and last longer.
Texaco used to have an abundance of information on their web site, but the last time I looked most of the information was gone. Fortunately I did print it for future reference.
Jim Johnson
98 SVT
#5214 03/17/02 09:31 AM
When I had the coolant flushed in my car I was told that it would benefit the system by putting in the additive that they had to lubricate the water pump!
Any thoughts on coolant additives?
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#5215 03/17/02 06:07 PM
What is the the best way to change the green antifreeze to DexCool. Draining the radiator, but how do you remove the green antifreeze from the
complete system before adding the DexCool?
#5216 03/18/02 12:09 AM
I read that you need to drain the green, flush with water till it is clear then add the DexCool!
Also if you can't flush it then just drain, fill with water, drain, fill with water again and drain. You should be ready to add the DrexCool now!
Stephen
Drop in K&N
#5217 03/18/02 07:46 PM
It MUST be 'clean of the green' - otherwise Long Life is contaminated , and only has the service life og the green.
