Page 3 of 9 1 2 3 4 5 6 7 8 9
Me Rikey
SVT Parts For Sale!PM Me. 2006 M6 Cyclone Gray GTO 1995 Mazda Protege Commuter Special 93 FXDWG Dyna Wide Glide I'm A TROLL Now!~
I
I
pretty nice, bet it wouldn't look half as good on a pre98 though
9
Originally posted by Swazo:
lol
While looking on some auto lighting forums I ran into a familiar CEG'er and his posts! I wonder which CEG'er would be doing that.........:X
me? hehehehh
but i am not planning on just slapping on the projectors on the pre98's I am trying to figure out a way to make a brand new headlight assembly at a reasonable cost
Prices I got upto now are crazy, lets say the cheapest was $15000 for the mold, for 1 side
3.0 14.392@97.237 2.302 60ft OEM 4-bolt LCA's $105 each Watch me go
Find someone in a college that has access to CNCs and all that good stuff. They might be able to get it sponsered for a school project. That would be dope.
Swazo Offline OP
I should've said "CEG'er's. It was you and a bit more higher profile CEG'er in the headlight field.
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
9
Let me guess? Quicksilver
BTW here is something else I found
3rd from the top
http://faq.auto.light.tripod.com/car-with-conv-oem-halo-projectors.htm
E
E
The was I was thinking of doing it to a pre-98 was to pick up a set of 90mm projectors (perhaps the E-codes from Puma, the Canada city-light model is kinda neat too). Anyway, take a set of lamps. Then find some 90mm ID plastic tubing. Seperate the lens from the housing. Place the lamps in the housing, with the lowbeam in the center (or modify a set of lows and remove the cutoff shield). The center lamps will be hidden slightly by the hood. After the lamps have been placed, then cut two round holes (90mm) into the lens. Sand and smooth the inside of the lens near where the plastic tubes will attach. Connect the tubes with some sort of epoxy. After everything is cured, then tape of the lamps and paint the lenses body color or whatever. Make sure the tubes don't touch the lamps so there is room for adjustment. These gaps will also allow a place for water to escape if you drive in the snow or rain (just put a drain in the stock lamp). Rewire the headlight harness using finer wire with a heavier guage. Connect HID to the lows and install into vehicle.
Thats how I would do it at least.
Very cool work on yours Swazo. I will want to take a look at them in person when I decide to chop into my lamps (again). How much better is the beam pattern? Do you think that those modules would also look good in the place of your foggies? How did you level them to work with the factory adjustment or is there a different place to adjust them now?
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
E
E
And..... Where did you get your lamps from anyway? Hella parts took FOREVER when I would order them from Checker.
9
Here is a good site with pretty good prices
E
E
I have that one at home. There are lots of other goodies on my computer too.
Here is one I can remember. I will have more when I get home tomorrow.
Moderated by  Keyser Soze
