#52101 01/23/02 01:00 PM
Chad Offline OP
My cel is flashing quickly and the car turns over but won't start. I was told it was a misfire and i disconnected the battery to reset the computer but it did it again a little later but it won't reset this time. I don't have a clue what to do.
#52102 01/23/02 01:09 PM
Disconnecting the battery will not correct a misfire. You prolly have one (if not 2-3) fouled plugs. Flashign CEL is no bueno. You need to get that crap checked out. Change you plugs and see if that help. If not, get to a mechanic...
1991 GVR4
Lots of mods done.
#52103 01/23/02 04:36 PM
Chad Offline OP
the car won't start because the cel is flashing so how do I get that fixed?
#52104 01/23/02 06:06 PM
no ****!!! sounds like you'll have to actually WALK to parts store :rolleyes: :rolleyes: :rolleyes:
damn ford...
seriously, though, you may want to check if all wires are connected properly and just look around. may be you get water in the spark plug wells, may be you have water on the coil pack...
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
#52105 01/23/02 08:26 PM
Chad Offline OP
were is the coil pack and what does it look like mad
#52106 01/23/02 08:46 PM
...just like a coil pack, you know... :rolleyes: :rolleyes: :rolleyes:
trace the spark plug wires back to the firewall. that's where the coil pack is
w/ this much experience I would call for a tow truck, though...
