Posts: 211 |
I was considering replacing the front stock motor mount with the performance urethane motor mount... My reasoniing for considering this is because I think this might be one of the factors that contributed to my 2 failed Differentials in less than 8 mounths.... I was just wondring if some of u guys could tell me some of the pros and cons of doing this and how hard is the install and how much time could one expect to spend replacing it!!! Maybe even a step by step if any of u have a few extra minutes!!!  Thanks in advance
1998.5 CSVT #3617
K&N Custom Intake
Custom 2 3/4 Magnaflow cat back
Ram HD Power Grip Clutch
Energy Suspension Inserts
Bosch Platnium +
Bf-Goodrich G-force radials "KDWS"
Alpine deck CDA-7863
Boston mids
More to come: Stock Sucks!!!!
Posts: 5,810 |
It is an insert that is used most of the time, and I think it helps a lot. It reduced the wheel hop I had a tremendous amount. I am going to fill the back mount pretty soon and recheck the front.
The front mount is easy enough, just some bolts to undo and redo.
warmonger
See My Mods
Posts: 211 |
I thought I seen on the BAT page a replacment mount that was solid and made of urethane!! I have also heard of these inserts that you are talking about!! Maybe someone could jump in and help me out??? Maybe tell me where the best place is to buy them!
Thanks again!!!!
1998.5 CSVT #3617
K&N Custom Intake
Bosch Platnium +
Boston mids
Posts: 392 |
Usually, you do not need to replace the whole motor mount unless it is broken. Just put in new polyurethane motor mount inserts. Energy suspension makes these and you can get them from SP Motorsports, CTA Motorsports, etc.
1998 SVT
Posts: 9,602 |
Originally posted by Baby SHO: you do not need to replace the whole motor mount unless it is broken. Just put in new polyurethane motor mount inserts.
Exactly.
While you are at it fill you other mounts with windshield urethane.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 5,854 |
Is this the same for the rear motor mount as well? the rubber in mine is shot and I was going to just replace the whole mount! But $20 for a set of inserts sounds better than $80 for a new mount all together!
1999 Silver Frost SVT
#609 of 2760
Posts: 837 |
How much would this decrease wheel hop by? How much for install?
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 90 |
why would you pay someone to install this
do it yourself it is an easy job
My Project: Cougar 2001 French Blue V6 MTX
Goal: A kickass ride!
My Website
Lots of cool pictures posted!
Posts: 211 |
What is windshield urethane and where do u get it, and if you can, give me a few of the details!!!!
Thanks
1998.5 CSVT #3617
K&N Custom Intake
Bosch Platnium +
Boston mids
Posts: 837 |
Well I'm not very knowledgeable when it comes to motor mounts, but wouldn't you need to get the motor off the old mounts to replace them with new ones? And that I wouldn't be able to do without the proper equipment.
So how much do the full urethane mounts decrease wheel hop by?
Also where exactly are the motor mounts located under the hood?
CSVT
Feels Like Heaven
Goes Like Hell
Profile
