#520727 01/11/03 04:46 PM
I was considering replacing the front stock motor mount with the performance urethane motor mount... My reasoniing for considering this is because I think this might be one of the factors that contributed to my 2 failed Differentials in less than 8 mounths.... I was just wondring if some of u guys could tell me some of the pros and cons of doing this and how hard is the install and how much time could one expect to spend replacing it!!! Maybe even a step by step if any of u have a few extra minutes!!!
Thanks in advance
1998.5 CSVT #3617 K&N Custom Intake Custom 2 3/4 Magnaflow cat back Ram HD Power Grip Clutch Energy Suspension Inserts Bosch Platnium + Bf-Goodrich G-force radials "KDWS" Alpine deck CDA-7863 Boston mids More to come: Stock Sucks!!!!
#520728 01/11/03 05:04 PM
W
W
It is an insert that is used most of the time, and I think it helps a lot. It reduced the wheel hop I had a tremendous amount. I am going to fill the back mount pretty soon and recheck the front.
The front mount is easy enough, just some bolts to undo and redo.
warmonger
#520729 01/11/03 05:36 PM
I thought I seen on the BAT page a replacment mount that was solid and made of urethane!! I have also heard of these inserts that you are talking about!! Maybe someone could jump in and help me out??? Maybe tell me where the best place is to buy them!
Thanks again!!!!
#520730 01/11/03 10:41 PM
Usually, you do not need to replace the whole motor mount unless it is broken. Just put in new polyurethane motor mount inserts. Energy suspension makes these and you can get them from SP Motorsports, CTA Motorsports, etc.
1998 SVT
#520731 01/12/03 05:14 AM
Exactly.
While you are at it fill you other mounts with windshield urethane.
#520732 01/12/03 06:29 AM
TGO Offline
Is this the same for the rear motor mount as well? the rubber in mine is shot and I was going to just replace the whole mount! But $20 for a set of inserts sounds better than $80 for a new mount all together!
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#520733 01/12/03 07:20 AM
How much would this decrease wheel hop by?
How much for install?
CSVT Feels Like Heaven Goes Like Hell Profile
#520734 01/12/03 04:01 PM
why would you pay someone to install this
do it yourself it is an easy job
My Project: Cougar 2001 French Blue V6 MTX Goal: A kickass ride! My Website Lots of cool pictures posted!
#520735 01/12/03 04:57 PM
What is windshield urethane and where do u get it, and if you can, give me a few of the details!!!!
Thanks
#520736 01/13/03 01:03 AM
Well I'm not very knowledgeable when it comes to motor mounts, but wouldn't you need to get the motor off the old mounts to replace them with new ones? And that I wouldn't be able to do without the proper equipment.
So how much do the full urethane mounts decrease wheel hop by?
Also where exactly are the motor mounts located under the hood?
