Page 3 of 3 1 2 3
#519890 02/01/03 02:58 AM
Originally posted by Big Jim:
I found that the rear check straps seemed to need lubing often, especially after rain. I found, as did an earlier poster, that marine grease stayed on longer. There must be a lot of water going through this area when it rains, just like the front door interior light switches. The natural result of long term lack of lubrication is worn parts. If you replace the door check straps, start off it's life with marine grease. If you have one that is not damaged yet, try the marine grease. It works for me!
Great advice, will do!!! I will be the proud owner of new, marine greased, rear door check straps that will outlast the rest of the 'tour!!!! Now there is something to be proud of ;-) ;-) Seriously, this is excellent advice Big Jim --- thank you for the continuing input!! Bill
#519891 02/01/03 03:50 AM
N
N
Heh, my dad told me to use lock lubricant it dried up in about 3 hours. I just tried some "3 in 1" household oil hopefully itll work.
1998 T-Red CSVT 3.0L
Page 3 of 3 1 2 3
