SVT_CT Offline OP
My ABS light is blown. It looks like a regular LED in a holder. Can anyone confirm this or set me straight?
99 Silver CSVT #1081/2760 97 Nissan Altima 83 Corolla SR5 RWD bondo/rust body 'ghetto cruiser' RIP 78 Winnebago Minnie (Dodge Chassis 23') 440cid 4bbl.
its not an LED, its a regular incandescent light bulb. They are available at your ford dealer.
SVT_CT Offline OP
thanks for the confirmation. It appears that the previous owner put an LED in the holder. With +12v across it and no resistor, it appears intended to blow. The ABS light will be on when I replace the bulb from what my meter tells me. Hopefully the ABS problem isn't expensive (slim chance).
FYI:
The light may normaly have +12VDC, with a switched GRD. When you use the meter measure across the two wires for the light.
'98.5 SVT E1 T-Red, Midnight Blue All stock
SVT_CT Offline OP
that's what I did. I replaced the bulb today and confirmed that the ABS indicator is on. It is under 60 day used car warranty still so I should have no problem.
Good work getting the light working while there is still waranty! So the light didn't work when you bought the car?
