#51897 01/19/02 12:29 PM
Brex Offline OP
Has anyone had this problem before? I replaced my cabin air filter, you know...the one that you need to open the hood, close the hood, have it propped halfway open, and re-open all the way to get at! Well turns out, the plastic is really brittle. My car has spent minimal hours in the sun just sittn' there so I'm guessing this was cheap plastic from the factory! I was replacing the plastic guards on the outside where the hood meets the windshield (the plastic in between where you can see the wiper motor through the slots) and the damn thing cracked on the passenger side! I couldn't believe it! Now I am ashamed but I have packing tape over the screw holes till I can replace it. Does anyone know of an aftermarket 'cool looking' replacment? Seeing as I have to replace it I was thinking of getting some black plexi moulded and fitted instead. What do you think? or get the factory crap dipped in hardend rubber or something to give it half a chance of surviving my next filter replacement. What a cheap way to fasten it too! Cheap little 'drywall anchor' like things that fit into a little slot and hold. I think the hood is doing most of the holding though. So in closing, if anyone is going to replace their filter, make sure you have a sickly 90 year old or an infant around when you're screwing the plastic covers back on. I used a drill with the clutch set to the weakest torque and CRAAAACCCCKKK! It still went bad! I know I'm getting further and further away from my question but I'm really pissed off about that! So any suggestions would be apreciated muchly (4:30 in morning, please ignore spelling)
Thanks!
'95 Contour SE
Black Current
MODS:
2.75 pipe with high flow muffler straight from cat, K&N Induction, High Power Stereo&Sub combo.
TO DO LIST:
Mags, Tires, Suspension, Performance Chip, ????
#51898 01/19/02 02:55 PM
Those little 'anchor pieces that go into the slots' are all busted off on mine too. The cowl is still all intact, just the parts that snap it to the car broke off. super glue worked good for putting them back on. My car is always garaged and only sits out for a few hours at a time so it's really sad at how brittle and cheap the plactic is! mad
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#51899 01/20/02 01:23 AM
Brex Offline OP
got it from a wrecker today for 30 bux...what a rip for crappy plastic that will break over and over again!
'95 Contour SE
Black Current
MODS:
TO DO LIST:
#51900 01/20/02 01:37 AM
$30!!! for cheap "used" plastic. I hope it was the entire cowl and not just one side...
James
jpett@flash.net
StolonTour97
#51901 01/20/02 09:55 AM
Brex Offline OP
I only busted the one side so I didn't care
'95 Contour SE
Black Current
MODS:
TO DO LIST:
